Constant Acceleration Car PRoblem
The discussion revolves around solving a physics problem involving constant acceleration while driving. Participants emphasize the importance of consistent unit conversion, particularly converting speeds from km/h to m/s and time from seconds to hours. The correct acceleration is calculated using the formula a = (V - V0) / t, leading to a displacement calculation with d = (V^2 - V0^2) / (2a). A common mistake identified is mixing units, which can lead to incorrect results. Ultimately, the key takeaway is the necessity of careful unit management to arrive at the correct answer.
Thiendrah
You're driving at 70 km/h when you accelerate with constant acceleration to pass another car. Six seconds later, you're doing 80 km/h.
How far did you go in this time?
Express your answer using two significant figures.
V= V(0)+at
V^2- V(0)^2 = 2a ( X-X(0) )
I keep finding some large numbers like 125000 m. I think I'm doing something wrong with converting times. So can someone tell me how to do this problem?
you kinda confused me.
That's what i did. I found the acceleration from the first equation. V=V(0)+at. I mean we know V=80km/h, V(0)= 70km/h, and t=6. Only thing left is a, right?. If i plug the acceleration i found with this in second equation. The answer isn't correct.
make sure one does not mix hours and seconds in the acceleration.
The v is given in km/h and the time in seconds.
One could certainly write the acceleration in km/h/s, but then when using v2 one would have units of (km/h)2.
I recommend converting km/h to m/s first.
It is better to show the work and make sure units are consistent.
Ok, here is a weird thing.
The site you gave me. I found the average velocity. Then that times with 6s gave me the displacement. which is the answer.
But the thing is i can't find the answer with those equations. It's basically the same thing. Still can't find it.
What you did is right, but you should watch the units. I repeated your calculation but put in the units...
For example (6 seconds = 60/10 seconds = 1/10 hour):
a = \frac{V - V_0}{t} = \frac{10\text{ km/h}}{1/10\text{ h}} = 100 \text{ km/h}^2.
Then from the second equation,
d \equiv (X - X_0) = \frac{ V^2 - V_0^2 }{ 2 a } = \frac{ \left( 80^2 - 70^2 \right) (\text{ km/h})^2 }{ 2 \times 100 \text{ km/h}^2 } = \frac{1500}{200} \frac{\text{km}^2 /\text{h}^2 }{ \text{km} / \text{h}^2 } = \frac{15}{2} \text{ km},
which IMO is still a lot (are the formulas right, did I make any calculation errors?) but better than 125 km :smile:
See how it works? Alternatively, you could have converted everything to m and s.
Yeah, your answer is correct too.
Only thing i did wrong was converting units. Everytime i did this problem, I'd have numerator and denominator in different units for the first equation.
Thanks both.
6 sec = 0.1 minute = 0.1/60 h or 6/3600 h = 0.00167 h ( 1 sec = 1/60 min = 1/3600 hr)
The delta-V = 80 km/h - 70 km/h = 10 km/h = 10000m/3600s = 2.78 m/s
dV/dt = 2.78 m/s / 6 s = 0.463 m/s2
or
10 km/h/ (0.00167 h) = 5988 km/h2
So one has to be careful with units.
Hehe, of course!
I thought there was a mistake somewhere.
Seven kilometers in 6 seconds seemed like a bit much :smile:
Thanks.
