Calculating Time for Constant Acceleration: Motorcycle Velocity Change
A motorcycle with a constant acceleration of 2.80 m/s² needs to change its speed from 40.9 to 50.9 m/s and from 70.9 to 80.9 m/s. The kinematic equation Vf = Vi + a*t is used to calculate the time required for these changes. An initial attempt incorrectly combined terms, leading to an incorrect solution of 4.04 seconds. The correct approach involves isolating the term with time (t) before solving. Proper algebraic manipulation is essential for accurate calculations in physics problems.
Erenjaeger
A motorcycle has a constant acceleration of 2.80 m/s2. Both the velocity and acceleration of the motorcycle point in the same direction. How much time is required for the motorcycle to change its speed from (a)40.9 to 50.9 m/s, and (b)70.9 to 80.9 m/s?
[/B]
Vf = Vi + a*t[/B]
using that kinematic formula,
for a) 50.9=40.9+2.8*t
then divide both sides by 40.9+2.8 to solve for t
answer = 4.04[/B]
and same thing with b) but in both cases the answer is coming up as wrong. what have i done wrong?
[/B]
Vf = Vi + a*t[/B]
answer = 4.04[/B]
You should check your algebra.
50.9 = 40.9 + 2.8t
is not the same thing as
50.9 = (40.9 + 2.8)t.
And for that matter, neither one gives an answer of 4.04 sec. So I'm not really sure what happened there.
(Hint, you can't just add 40.9 plus 2.8 that way. That's not the way algebra works.)
50.9 = 40.9 + 2.8t
oh right, so basically i have to get 2.8t on its own and then divide by 2.8??
Likes collinsmark
Yes, that is the correct way. :smile:
cool thanks!
Likes Kuzon and collinsmark
