How Is Acceleration Calculated for a Bullet in a Rifle Barrel?
To calculate the acceleration of a bullet in a rifle barrel, the length of the barrel (0.877 m) and the bullet's exit speed (612 m/s) are used. Assuming constant acceleration for simplicity, the formula v² = u² + 2as is applied, where v is the final velocity, u is the initial velocity (0 m/s), a is acceleration, and s is the distance (0.877 m). Rearranging the formula allows for the calculation of acceleration, resulting in approximately 227,000 m/s². This high acceleration reflects the rapid increase in speed as the bullet travels through the barrel.
iiskenny
The barrel of a rifle has a length of 0.877 m. A bullet leaves the muzzle of a rifle with a speed of 612 m/s.
What is the acceleration of the bullet while in the barrel? A bullet in a rifle barrel does not have constant acceleration, but constant acceleration is to be assumed for this problem.
Answer in units of m/s2.
Post your attempt.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
