Constant solutions to the Lagrange equations of motion
bobred
A particle moves on the surface of an inverted cone. The Lagrangian is given by
t%29%5Cdot%7Br%7D%5E%7B2%7D+r%5E%7B2%7D%5Cdot%7B%5Cphi%7D%5E%7B2%7D%20%5Cright%29-mg%5Calpha%20r.png
Show that there is a solution of the equations of motion where
and
take constant values
and
respectively
The equations of motion
and
are
tex?%5Cddot%7Br%7D+%5Calpha%5E%7B2%7D%5Cddot%7Br%7D-r%5Cdot%7B%5Cphi%7D%5E%7B2%7D+g%5Calpha%20=0.png
(1)
(2)
So
can be eliminated from equation (1)
Would I go about this by setting
equal to a constant,
, and similarly for
, and similarly for
It is not \ddot{r}, \dot{\phi} that you were asked to show provide a solution, but {r}, \dot{\phi}. These requirements define uniform circular motion. The question is thus asking you to use the equations to check that uniform circular motion is a solution.
Likes bobred
If ##r(t) = r_0## (a constant), what is ##\ddot{r}(t)##?
Likes bobred
What do you get when you differentiate a constant?
Differentiating a constant is zero.
I was thinking about the equations in isolation to each other and not as part of a system. So
v=r \dot{\phi}=r_0 \Omega
I just need to show that the equations of motion lead to this.
No: they do not "lead to" this; they merely allow this.
There is a big difference, since (due to the lack of friction) a solution with non-constant ##r## and ##\dot{\phi}## never settles down to a limiting orbit of constant ##r## and ##\dot{\phi}##. However, if you start off with the correct initial conditions, your orbit maintains constant ##r## and ##\dot{\phi}## forever. Essentially, that is what you are being asked to verify.
So setting the acceleration \ddot{r}=0 leaves a constant r and \dot{\phi} which allows the uniform motion.
