Constant velocity moments problem
When an object rotates about an axis with constant velocity, the sum of the acting moments, or torque, is indeed zero because there is no angular acceleration. The relationship between moment, mass, acceleration, and distance supports this conclusion, as moment is defined as mass times acceleration times distance. Since acceleration is zero in this scenario, the resulting moment is also zero. Therefore, the assumption that the acting moment is zero under constant velocity rotation is accurate. This understanding is crucial for analyzing rotational dynamics in physics.
Ry122
If a something is rotating about an axis with a constant velocity is the sum of the acting moments 0 since no acceleration is occurring?
Moment = mass x acceleration x distance
If acceleration is 0, the moment is 0.
Is this correct?
I'm assuming that by acting moment you mean torque, in which case yes, that is correct.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
