Constrained Lagrangian equetion (barbell)
  • Context: Graduate
  • Thread starter Thread starter Jengalex
    Lagrangian
The discussion focuses on the dynamics of an ideal barbell-shaped object using Lagrangian mechanics. The Lagrangian is defined as L = (m/2)(\dot{x_1}^2 + \dot{x_2}^2 + \dot{y_1}^2 + \dot{y_2}^2) - U(x_1, y_1) - U(x_2, y_2), with a constraint f = (x_1 - x_2)^2 + (y_1 - y_2)^2 - L^2 = 0. The user initially derived equations of motion but encountered inconsistencies due to treating the system as having four degrees of freedom instead of the correct three. A suggestion was made to reformulate the Lagrangian using three independent generalized coordinates, which resolved the issue.
  • Understanding of Lagrangian mechanics
  • Familiarity with constraints in dynamical systems
  • Knowledge of partial derivatives in the context of potential energy
  • Ability to work with generalized coordinates
  • Study the formulation of Lagrangians for constrained systems
  • Learn about generalized coordinates and their applications in mechanics
  • Explore the concept of degrees of freedom in mechanical systems
  • Investigate the use of Lagrange multipliers in constraint problems
Students and professionals in physics, mechanical engineering, and applied mathematics who are interested in advanced dynamics and Lagrangian mechanics.
Jengalex
Hi!
I tried to compute an ideal barbell-shaped object's dynamics, but my results were wrong.
My Langrangian is:
## L = \frac{m}{2} ( \dot{x_1}^2 + \dot{x_2}^2 + \dot{y_1}^2 + \dot{y_2}^2 ) - U( x_1 , y_1 ) - U ( x_2 , y_2 ) ##
And the constraint is:
## f = ( x_1 - x_2 )^2 + ( y_1 - y_2 )^2 - L^2 = 0 ##
I dervated L + λf by ## x_1, x_2, y_1, y_2 ## and λ:
## m \ddot x = - \frac{\partial U}{\partial x_1 } + \lambda ( x_1 - x_2 ) ## (1)
Four equtions similar to this and the constraint.
Then I expressed ## \ddot x_2 , \ddot y_1 , \ddot y_2 ## with ## \ddot x_1 , x_1 , x_2 , y_1 , y_2 ## and U's partial derivates' local values:
## m \ddot x_2 + \frac{\partial U}{\partial x_2} = - m \ddot x_1 - \frac{\partial U}{\partial x_1} ##
## m \ddot y_2 + \frac{\partial U}{\partial y_2} = - m \ddot y_1 - \frac{\partial U}{\partial y_1} ##
## ( m \ddot y_1 + \frac{\partial U}{\partial y_1} )(x_1 - x_2) = (- m \ddot x_1 - \frac{\partial U}{\partial x_1})(y_1 - y_2) ## (2)
After expressing ## (x_1 - x_2) , (y_1 - y_2) ## and ## \lambda ## from equation (1) and (2), substituted it into the constraint equation I got an equation like this:
## (m \ddot x_1 + \frac{\partial U}{\partial x_1} ) * <something> = 0 ##
I think it's wrong.
Can you confirm or point on my mistake?
Jengalex said:
Hi!
My Langrangian is:
## f = ( x_1 - x_2 )^2 + ( y_1 - y_2 )^2 - L^2 = 0 ##I dervated L + λf by ## x_1, x_2, y_1, y_2 ## and λ:
I think it's wrong.
I don't know what a "barbell-shaped dynamics" is, but if in your problem in the plane with two points there is a constraint, the degrees of freedom are 3, not 4, so I would have written the Lagrangian as function of 3 independent generalized coordinates, for example x1, y1 and the angle between the line connecting the two points (P1 = (x1,y1); P2 = (x2,y2)) and the x axis.
Yes I've tried it now, it looks fine. Thanks!
