How do contact forces affect collisions and object launches?
Contact forces play a crucial role in both collisions and object launches, particularly when analyzing systems where bodies are initially at rest. The discussion highlights the importance of applying conservation of momentum and energy principles to solve problems involving elastic and inelastic collisions. When a girl on frictionless rollers launches a ball, the outcome can be calculated using work done and the resulting velocities, while ensuring that forces exerted are equal and opposite, as per Newton's third law. The concept of impulse, defined as the change in momentum over time, is also relevant in understanding these interactions. For further clarity, resources like Hyperphysics can provide comprehensive equations and explanations for these physical phenomena.
alba
I have recently studied collisions, in which one or two bodies are already in motion.
I have tried to apply them to cases in which the bodies are initially at rest, like launching or kicking a ball etc, but they do not work.
Can you tell me how to google to find them, 'contact force' gives everything, I tried 'explosive forces' but I get only explosives.
Can you help me?:
suppose a girl (20 kg) on frictionless rollers launches a ball (1kg) doing work 210 J, what is the rule to find the outcome?
I imagine that if she pushes at a wall the outcome is the same of an elastic collision with a wall of a body of 20kg, , if so, she will move backward at v = √210*2/20 = - 4.58 m/s. Is that right?
Is the force on the wall equal to the force that acts on the girl? and what about momentum? the girl's is -91.6 kgm/s the wall's should be the same, but in that case it would mean it subtracted energy to the girl and her speed will be less?
How do I deal with the ball? do you have a link or a formula?
Thanks
If you can already 'do' objects in motion then why not just put the initial velocity of one of them to zero? If you are not getting the right answer, it could be that you are not doing the right sum. Have you looked at the Hyperphysics pages on Elastic and Inelastic Collisions? All the relevant equations and ideas are presented there, although you have to learn to drive their system to get the most out of it.
The way to solve specific problems will depend upon what you are given. If the collision can be assumed to be elastic then no energy is 'lost' and you can use conservation of Energy. If not, you can always rely on Momentum being conserved. Newton 3 always applies, of course.
Have you come across the quantity 'Impulse'? That is the Change in Momentum and is given by the Force times the Time it's applied.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
