What is the largest real number one can write within 200 characters?
  • Thread starter Thread starter micromass
    Contest
The discussion revolves around a playful challenge to create the largest real number within a 200-character limit, using standard mathematical functions and notations. Participants debate the effectiveness of various notations, including Knuth's up-arrow notation and factorials, to express extremely large numbers. There is a focus on Graham's number and its implications for size comparisons, with users attempting to outdo each other by proposing increasingly complex expressions. The conversation highlights the challenge of adhering to the rules while still aiming for the largest possible number. Overall, the thread showcases creativity in mathematical expression and the competitive spirit of the participants.
  • #101
In 5 characters, using only standard operations, and obeying the standard order of operations (thus sometimes requiring parentheses!), I think the best you can do is
(9!)!
  • #102
I don't care about Graham cracker's number! I just like googol! :partytime:
  • #103
I agree with jfizzix
  • #104
The following may seem similar to Berry:
Code:
The largest number for which any human will ever write a formula or algorithm in the past and future history of the Earth
But, because it doesn't contain the negation of the Berry/Russell version, it is perfectly well-defined and non-paradoxical. It's just that we'd have to wait for the destruction of the Earth for somebody to compute it.
If I put some Knuth arrows at the end of it (there were some characters to spare), it would become self-referential and paradoxical.
  • #105
andrewkirk said:
Code:
Someone could express Rayo's[/PLAIN] number \text{Rayo}(10^{100}) on Mars, and then you lose ... :wink:
Code:
The smallest number bigger than any finite number named by an expression in the language of set theory with a googol symbols or less.
  • #106
Code:
Graham's number < googology.wikia.com/wiki/TREE(3) < googology.wikia.com/wiki/SCG(13)
You didn't say anything about links! :biggrin:
BIG FOOT: \text{FOOT}^{10}(10^{100}) is of course much bigger, but I guess it's disqualified ...
  • #107
Python:
def FindGraham(s):
    if 'G' in s or 'g' in s:
        return True
    return False
print FindGraham("***")
where *** I put your string, guess now ; the result was false..
by a small modification I even got your character count:
870
Maybe you can fool the eye but not the PC...
  • #108
Code:
bit.ly/1RFruCp
bit.ly/1OtaqP9
b(x)=busy beaver function
f=BIGFOOT
v(x)=b(f) recursions of b
r(x)=v(f) recursions of v
z(x)=r(f) recursions of r
11 in base z(f)
  • #109
Code:
G=Graham's Number
G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G[G]G
  • #110
What does [G] mean?
  • #112
I think there should be a time limit to the contest too. Otherwise people just continue nesting things together.
Also I really can't wait to see how micromass is going to judge which of the numbers given in this thread is bigger!
  • #113
Vanadium 50 said:
How about 7, only with a font size of 9.999 x 10^92?
You did ask for the largest number, and not the number of greatest possible magnitude.:devil:
In the same spirit:
Code:
[itex]9.\overline{9}[/itex] is the largest (widest) number, as it has an infinite amount of characters to display
  • #114
jack action said:
In the same spirit:
Code:
So is ##10.\overline{0}##
The ##0##'s are left out for convenience but really should be there.
  • #115
int y=100000000;
for(x=0;x<-1;x++)
y=y*y
(never said we could use code)
  • #116
y is 32 bit int?
  • #117
Patrick_Hutecker said:
int y=100000000;
for(x=0;x<-1;x++)
y=y*y
Since you initialize x to zero, the condition in the for-loop will be false and it will not run your statement.
Likes collinsmark
  • #118
ah that too
i'm convinced the true winner in this is some perl one liner though, busy beaver be damned
  • #119
While true n = n + 1
  • #120
Doesn't terminate so not a valid number.
Likes collinsmark
  • #121
We have defined a size of an infinite set a valid cardinal number, haven't we ? -/+infinity is an extended real number until you hit Control+C.
  • #122
Micromass would have to confirm, but I'm assuming that rule 1 for the contest implies extended real numbers are not permitted since it explicitly prohibits the use of infinity.
  • #123
Indeed, only real numbers are allowed.
  • #124
Code:
 The number of seconds required to calculate the number of digits in every number in this thread using an abacus, an unlimited supply of paper and pencils, and a wooden spoon.
Likes ProfuselyQuarky and JorisL
  • #125
Still much more real than many.
  • #126
Drakkith said:
Code:
Nice but, sadly, non-computable, owing to its self-referentiality generating an infinite regress. But if you added 'other than posts 104 and 124' it would work.
Likes Drakkith
  • #127
Doesn't matter, he and everybody else who try looping/recursive code tricks, will inevitable run out of RAM before even getting close to Graham's number [or TREE(3) or SCG(13) or BIG FOOT]. It won't work even if you turn the whole observable universe into a Samsung semiconductor plant ... :smile:
Likes micromass
  • #128
That's okay. I still have my spoon.
Likes andrewkirk and collinsmark
  • #129
I'm using java and that is an endless loop. The loop will run even if x is zero, if you think otherwise I don't think you know code.
  • #130
The number I'm producing is something and its called infinity. You can't show infinity on a computer, which doesn't make it false or not a concept. Just because their isn't enough ram to make my number doesn't mean it does exist.
  • #131
Infinity is not a real number.
  • #132
ok its a concept you got me there
  • #133
I think you should probably try and run your code before suggesting someone "doesn't know code". The fact that the condition in your for-loop will always be false is not the only problem with your "endless loop". Your program won't even run because you didn't define a data type for 'x' and you missed a semicolon at the end of your statement in the for-loop.
  • #134
Not to mention the fact y can't hold number larger than MAXINT (whatever it is in the particular system - assuming Java it should be +9,223,372,036,854,775,807). If memory serves me well, Java won't even tell you there was an overflow.
Not to mention the fact OP never stated it is Java and it can be C or C++ as well (not that it changes the code behavior or problems it has).
Likes Dembadon
  • #135
Can we use busy beaver, or do the functions have to be computable?
  • #136
Assuming that we can...here's a start:
Code:
Defs: [BB=busy beaver; f^n=f composed w/self n times; f→m→n=f^(m^(m…), m appears n times; g64=Graham’s #], number: (BB(g64)→BB(g64)→BB(g64))→(BB(g64)→BB(g64)→BB(g64))→(BB(g64)→BB(g64)→BB(g64))
8 characters to spare, just to leave room for someone to top it!
Edited to make BB^n definition clearer.
  • #137
You are using "int y=100000000;" and the int64 unsigned range is 0 to 18,446,744,073,709,551,615 which is quite far from both infinity and Graham's number ...
Now, it's true that you can "show" many (virtual) things on a computer (including flying dogs), and one way to handle extremely large numbers is the binary64 double-precision floating-point format, with a max exponent of 1023, however the numbers you get is rounded approximations and does not qualify as a real number.
Beyond that, there is Arbitrary-precision arithmetic, that was originally implemented in Lisp and nowadays is supported in most modern languages like Java, Ruby, C/C++, etc. Using this technique, the digits of precision are limited only by the available memory of the host system (including integer). The processing speed is naturally much slower, since fast CPU registers can not be utilized as normal.
This brings us back to the "Observable Universe Samsung Semiconductor Plant", which is the final inexorable bottleneck for digital precision computing.
Why!?
Well, let's say Samsung finds a very clever way to utilize every particle in the observable universe for storing one digital bit (1/0) — how man many bits can we store?
10^{90} bits
Normally the approximation is 10^{80} atoms in the observable universe, but Seth Lloyd (MIT) has published a paper Computational capacity of the universe where he calculate the number of bosons and fermions (particles/antiparticles) and thus get the bigger number (he also take gravitational energy into account but that's overkill = 10^{120} bits).
So, how big is the digital number Samsung/Seth Lloyd can ever store in the entire observable universe?
2^{10^{90}}
That's a very big number, and I tried the Big Online Calculator (with 2048 bits mantissa and 256 bits exponent) but it halted at 2^{10^{76}} and returned:
1.75\times 10^{301029995663981195213738894724493026768189 8814621085413104274611271081892744}
Not giving the full picture, that's a hefty number ...
But how hefty is it in comparison with the Real Monsters? Well, we can directly see that the 'tiny' (in this league) Googolplex 10^{10^{100}} is already much bigger.
Conclusion: If you use a digital computer to find the largest number — you're doomed to lose.
(And that goes for seconds and abacus as well, unless you plan to live longer than the universe! :wink:)
Likes diogenesNY
  • #138
Code:
Defs: [BB=busy beaver; f^n=f composed w/self n times; f→m→n=f^(m^(m…), m appears n times; gr=Graham’s #], number: (BB(gr)→BB(gr)→BB(gr))→(BB(gr)→BB(gr)→BB(gr))→(BB(gr)→BB(gr)→BB(gr))
Code:
11 in base^
(changed g64 to gr to save a few characters)
can we use BIG FOOT or TREE(3) without links? (don't really understand either but pretty sure they're exact finite numbers)
  • #139
Darn, I was going to use my abacus :oldlaugh:
  • #140
:biggrin:
  • #141
0.3(3)
  • #142
I don't know about you, but I plan to live forever.
Likes ComplexVar89 and ProfuselyQuarky
  • #143
Hoping is different from planning. And I'm pretty sure you only hope to live forever!
Likes ProfuselyQuarky and Drakkith
  • #144
And planning is different from knowing :biggrin:
Drakkith knows that he's not going to live forever (I hope)
  • #145
Way to dash my hopes and dreams... :cry:
  • #146
There, there. My dream was to prove that narwhals are really unicorns undercover, but I soon got over it
Likes Samy_A and Drakkith
  • #147
Who says they're not?:wink::wink:
  • #148
Aha! A believer! Try telling that to a biology teacher :woot:
**I, for one, have done just that and do NOT recommend it**
  • #149
Or die trying?
Likes atyy, ComplexVar89, Dembadon and 1 other person
  • #150
No worries, mate. I'm almost a little bit jealous ... imagine 4-8 billion* years from now, when the Milky Way and Andromeda merge into one ... man, talk about fireworks.
On the other hand, the Dark Era in 10^{100} years, doesn't look that tasty ... photons, neutrinos, electrons, and positrons flying from place to place, hardly ever encountering each other, and on top of that; a terribly unstable abacus and wooden spoon + the knowledge that you have only come halfway in this hair-raising PF Contest ... :rolleyes:
*Of course, that little hiccup of the Sun turning into a red giant, can easily be fixed with a wooden spoon and some perkiness.
Likes Drakkith and ProfuselyQuarky
