Continuity of piecewise function of two variables
The discussion revolves around the continuity of a piecewise function of two variables, defined as f(x, y) = 0 for y ≤ 0 or y ≥ x^4, and f(x, y) = 1 for 0 < y < x^4. Participants explore the behavior of this function as (x, y) approaches (0, 0) along various paths and the implications for continuity at that point.
  • Participants discuss the conditions under which f(x, mx^a) can equal 1 and question the implications of approaching (0, 0) along different paths. There are inquiries about the continuity of the function along the y-axis and the necessity of epsilon-delta definitions in proving continuity or discontinuity. Some participants suggest examining points arbitrarily close to (0, 0) to illustrate discontinuity.
The discussion is active, with participants raising various questions and exploring different paths of reasoning regarding the function's continuity. Some guidance has been offered regarding the use of epsilon-delta definitions and the nature of continuity in relation to the function's piecewise definition.
Participants are considering the implications of approaching the point (0, 0) from different directions and the specific conditions under which the function changes value. There is an emphasis on the need for rigorous proof and the exploration of assumptions related to the function's behavior near discontinuities.
A330NEO
The question looks like this.
Let ##f(x, y)## = 0 if [itex]y\leq 0[/itex] or [itex]y\geq x^4[/itex], and [itex]f(x, y)[/itex] = 1 if [itex]0 < y < x^4[/itex].
(a) show that [itex]f(x, y) \rightarrow 0[/itex] as [itex](x, y) \rightarrow (0, 0)[/itex] along any path through (0, 0) of the form [itex]y = mx^a[/itex] with [itex]a < 4[/itex].
(b) Despite part (a), show that [itex]f[/itex] is discontinuous at (0, 0)
(c) Show that [itex]f[/itex] is discontinuous on two entire curves.
What I've came to conclusion is that when [itex]x<0, m>0[/itex], and [itex]a[/itex] being an odd number, [itex]y[/itex] becomes smaller then zero, so [itex]f(x, y)[/itex] can't be any larger than zero. But I don't think that's not enough. I think I need to find a way to generalize that [itex]mx^a (a<4)[/itex]is larger than [itex]x^4[/itex] or smaller than 0 when [itex]x[/itex] and [itex]y[/itex] is close enough to zero, where I cant' quite get to.
In regarding (b), I know [itex]f(x, y)[/itex] is discontinuous on certain directions, but can't elaborate it in decent form.
In regarding (C), How can I show it?
For (a): The only way [itex]f(x,mx^a)[/itex] can equal 1 is if [itex]0 < mx^a < x^4[/itex]. If both [itex]m[/itex] and [itex]x^a[/itex] are positive then this requires [itex]|x| > m^{1/(4 - a)}[/itex]. Is that true as [itex]|x| \to 0[/itex], or is there a point beyond which this constraint is violated? What can you say about the case when both [itex]m[/itex] and [itex]x^a[/itex] are negative?
For (b): Can you show that there are points (x,y) arbitrarily close to (0,0) for which f(x,y) = 1, and yet f(0,0) = 0?
For (c): Use the above idea: Let (X,Y) be a point on such a curve; you need to show that there are points (x,y) arbitrarily close to (X,Y) such that [itex]|f(x,y) -f(X,Y)| = 1[/itex].
I know why the curve is incontinuous except for points on x-axis or y-axis, but I want to know how to prove it elaborately. How can I do that? can it be done by epsilon-delta? If so, then how? If not, what is the 'other way'?
The definition of continuity at a point is:
"[itex]f: \mathbb{R}^2 \to \mathbb{R}[/itex] is continuous at [itex]\mathbf{a} \in \mathbb{R}^2[/itex] if and only if for every [itex]\epsilon > 0[/itex] there exists a [itex]\delta > 0[/itex] such that for all [itex]\mathbb{x} \in \mathbb{R}^2[/itex], if [itex]\|\mathbf{x} - \mathbf{a}\| < \delta[/itex] then [itex]|f(\mathbf{x}) - f(\mathbf{a})| < \epsilon[/itex]".
The negation of that is:
"[itex]f: \mathbb{R}^2 \to \mathbb{R}[/itex] is not continuous at [itex]\mathbf{a} \in \mathbb{R}^2[/itex] if and only if there exists an [itex]\epsilon > 0[/itex] such that for all [itex]\delta > 0[/itex] there exists an [itex]\mathbf{x} \in \mathbb{R}^2[/itex] such that [itex]\|\mathbf{x} - \mathbf{a}\| < \delta[/itex] and [itex]|f(\mathbf{x}) - f(\mathbf{a})| \geq \epsilon[/itex]."
Understood. But, if we approach (0, 0) along the y-axis, regardless of if y >0 or y<0, isn't it continuous? Is it considered discontinuous because there is no 'width' of the contacting point?
Any non-constant function from the plane to {0,1} is of necessity discontinuous. If you compose such a function with a path on which the function is constant, then the result is a constant function from (an interval of) the reals to {0,1}, which is continuous. Here the y-axis lies entirely within the region in which f = 0. There are, of course, points arbitrarily close to (0,0) which lie in the region in which f = 1, which is why f is not continuous at (0,0).
If you want an epsilon-delta proof of that, take [itex]\epsilon = \frac12[/itex] and [itex]\delta > 0[/itex] arbitrary. Let [itex]\delta' = \min\{\delta, 2^{4/3}\}[/itex] and consider the point [itex](\frac12 \delta', \frac{1}{32}\delta'^4)[/itex]. This by construction satisfies [tex] \|(\tfrac12 \delta', \tfrac{1}{32}\delta'^4)\| = \left( \frac14 \delta'^2 + \frac{1}{2^{10}}\delta'^8\right)^{1/2} < \sqrt{\tfrac12 \delta'^2} < \delta[/tex] and [tex]f(\tfrac12 \delta', \tfrac{1}{32}\delta'^4) = 1.[/tex]
  • · Replies 40 ·
  • · Replies 27 ·
