Asphyxiated
- 263
Continuous Functions - Setting up word problems
Each side of a square is expanding at 5 cm/sec. What is the rate of change when the length of the sides are 10 cm.
A = ab
a = 5t, b = 5t
and the area is described as A = ab
so the rate of change in the area should be
\frac {dA}{dt} = a \frac {db}{dt} + b \frac {da}{dt}
then \frac {da}{dt} = 5 and \frac {db}{dt} = 5
so \frac {dA}{dt} = 5a + 5b
then at t = 2
\frac {dA}{dt} = 5 *10 + 5 *10 = 50 + 50 = 100 cm^{2}/sec
So the area of the square is changing at a rate of 100 sq cm/sec when the sides are at 10 cm
is this correct?
A = ab
a = 5t, b = 5t
then at t = 2
is this correct?
