Contraction of a tensor to produce scalar
The contraction of the tensor ##T^{\beta \gamma}_{\delta \epsilon}## produces a scalar T through the equation $$T^{\beta \gamma}_{\delta \omicron}T_{\beta \gamma}^{\delta \omicron} = T$$. Proper use of LaTeX is essential for displaying mathematical expressions accurately in forum discussions. The correct syntax for in-line formulas is to use "# #" and for displayed equations, use "$$ $$". This ensures clarity and correctness in mathematical communication.
  • Understanding of tensor notation and operations
  • Familiarity with LaTeX syntax for mathematical expressions
  • Knowledge of covariant and contravariant tensors
  • Basic concepts of scalar quantities in tensor calculus
  • Research LaTeX formatting for mathematical expressions
  • Study the properties of covariant and contravariant tensors
  • Learn about tensor contraction and its applications in physics
  • Explore advanced tensor calculus techniques
Students and professionals in mathematics, physics, and engineering who are working with tensor analysis and require clarity in mathematical notation.
roberto85
Explain how it is possible to perform a contraction of the tensor
##T^{\beta \gamma}_{\delta \epsilon}## in order to produce a scalar T
$$T^{\beta \gamma}_{\delta \epsilon}T_{\beta \gamma}^{\delta \epsilon}=T$$
Not sure if that is correct? Also not used the forums in a while so not sure I am using the LaTex correctly here.
$[T^{βγ}_{δǫ}]$ in order to produce a scalar T
$[T^{βγ}_{δǫ}] [T_{βγ}^{δǫ}] = T$
Not sure if that is correct? Also not used the forums in a while so not sure I am using the LaTex correctly here.[/B]
You can tell you are not using LaTeX properly, just by reading your own message. For in-line formulas and equations, use "# #" (with no space between the two #s) instead of "$" at the start and end of you object. Also: spell out the actual names of the Greek symbols, so that β is "\beta" (backslash + 'beta'), etc. For your first formula this gives ##T^{\beta \gamma}_{\delta \omicron}## (if the object "ǫ" is an ##\omicron##---I could not figure it out).
For a displayed formula or equation, just use two $ signs (with no space between them) at the start and the end. That gives
You can right-click on a formula or equation and ask for display as TeX, to see the commands used in the above two examples.
Thanks Ray, i just edited the equation but can't see why its not displaying correctly? edit: i see now, sorry. Is that correct to say then that the covariant multiplied by the contravariant will reduce it to a scalar?
