Contradictions in Irrotational Vortex?
In summary, the Wikipedia article explains that in Irrotational vortices, the fluid's flow velocity is inversely proportional to the distance from the vortex's axis. However, there is also friction between adjacent streamlines, causing energy loss near the core/axis. This friction increases with input energy and can be compared to a car on the highway needing more gas. The effect of passing a vortex through a Venturi tube on rotational velocity depends on the specific setup.
Stevenyzs
So I was reading about Vortices in Wikipedia, when I stumbled upon the explanation about Irrotational Vortices.
It states there that in Irrotational vortices, the fluid's flow velocity u, is inversely proportional to the distance r, from the vortex's axis.
Then, at the end of the explanation, it says that: "In an irrotational vortex, fluid moves at different speed in adjacent streamlines, so there is friction and therefore energy loss throughout the vortex, especially near the core." So the fluid's speed increases and decreases at the same time near the core/axis??
http://en.m.wikipedia.org/wiki/Vortex
Is that question meant in time or in space?
You need some external force to keep the fluid rotating.
Nah, I'm referring to general physics, not the space time stuff.
Like for example, when you whirl your hand in a bucket of water, you'll create an Irrotational vortex right? And the explanation provided by
Wikipedia first says that the fluid's speed in an Irrotational vortex is inversely proportional to the distance from it's axis.
It then proceeds to say that the different speed in adjacent streamlines, will cause friction between the streamlines, thus causing energy loss throughout the vortex, especially near the core/axis.
So isn't that a contradiction...?
Classical physics, sure.
There is a difference between "it gets hotter towards the equator" and "it gets hotter towards noon". So "it gets hotter" is ambiguous if you have both a space direction (towards/away from the center) and time (evolution of the system due to friction).
You have more energy loss near the core, so what? Your input power is also near the core.
A car on the highway has more friction and more speed than a car on other roads. Same comparison, no contradiction. The car on the highway just needs more gas.
So are you saying that the friction between the streamlines are somewhat constant, and more input energy is needed for a narrow Irrotational vortex...?
Constant in which aspect?
If that is the only difference: sure.
Constant, like the coefficient of friction mew, between the streamlines. Cos the more input energy you use to induce a faster vortex, the larger the frictional forces...right?
You have a fluid, friction in fluids is not a dimensionless coefficient.
Yes, the faster your vortex the larger your friction (in terms of power), similar to the highway&car example from above.
So for example, if I were to pass a vortex through a Venturi tube, would the rotational velocity increase due the vortex being closer to it's axis, or would the increase in frictional forces cancel it out?
That depends on details of the setup.
Related to Contradictions in Irrotational Vortex?
1. What is an irrotational vortex?
An irrotational vortex is a fluid flow that has no net rotation at any point. This means that the fluid particles move in circular paths without any spinning motion.
2. How are contradictions possible in an irrotational vortex?
Contradictions in an irrotational vortex can occur due to the complex nature of fluid flow. Even though the overall flow is irrotational, small areas of local rotation or eddies can form, leading to contradictory behavior.
3. What are some real-world examples of contradictions in irrotational vortex?
One example is the flow of water around a spinning basketball. While the overall flow is irrotational, small eddies can form behind the ball, creating contradictory flow patterns. Another example is the flow of air around an airplane wing, where small vortices can form at the wingtips, leading to contradictory lift forces.
4. How do scientists study and understand contradictions in irrotational vortex?
Scientists use mathematical models and computer simulations to study and understand the complex nature of fluid flow. They also conduct experiments in controlled environments to observe and analyze the behavior of irrotational vortices and their contradictions.
5. Can contradictions in irrotational vortex be avoided or eliminated?
While it is not possible to completely eliminate contradictions in irrotational vortex, scientists and engineers can minimize their effects by designing and optimizing systems to reduce the formation of small eddies or by using techniques such as flow control to manipulate the fluid flow.
  • STEM Academic Advising
  • General Engineering
  • Mechanical Engineering
  • Other Physics Topics
