Convergence of Sequence Proof: Is This Correct?
7 replies · 1K views
Mr Davis 97
Prove rigorously that ##\displaystyle \lim \frac{n}{n^2 + 1} = 0##.
A sequence ##(s_n)## converges to ##s## if ##\forall \epsilon > 0 \exists N \in \mathbb{N} \forall n \in \mathbb{N} (n> N \implies |s_n - s| < \epsilon)##
Let ##\epsilon > 0##. Let ##\displaystyle N = \frac{1}{\epsilon}##. Let ##n \in \mathbb{N}##.
Then, if ##n > N##, we have that ##\displaystyle n > \frac{1}{\epsilon}## and so ##\displaystyle \frac{1}{n} < \epsilon##. Therefore, ##\displaystyle |\frac{n}{n^2+1} - 0| = \frac{n}{n^2+1} < \frac{n}{n^2} = \frac{1}{n} < \epsilon##. This proves that ##\displaystyle \lim \frac{n}{n^2 + 1} = 0##.
Is this a correct convergence proof?
LCKurtz said:
Looks OK to me.
I actually have a concern. I let ##\displaystyle N = \frac{1}{\epsilon}##, but by the definition of sequence convergence, shouldn't ##N## be an integer? Is this a problem? How could I fix it?
Take N = ##\lceil \frac 1 \epsilon \rceil##, IOW, the smallest integer greater than or equal to ##\frac 1 \epsilon##.
Nothing requires N to be an integer. It is the n > N that is an integer.
Well my definition claims that ##N## is a natural number. Would Mark44's approach suffice?
@Mr Davis 97, you're overthinking this. If ##\frac 1 \epsilon## isn't an integer, just take N to be the next-larger integer, which is basically what I said before. After all, N is just a lower bound on the indexes of the sequence elements that are "small enough." Elements further in the sequence will be even smaller; i.e., closer to zero.
