Convergence or divergence (series)
The discussion revolves around the convergence or divergence of the series Ʃ[(-1)^n (cosn)^2]/√n, which involves an alternating series with terms that depend on the cosine function and a square root in the denominator.
  • Exploratory, Assumption checking
  • Participants discuss the use of the Alternating Series Test and the conditions required for convergence, including the limit of the terms and their ordering. There is also a question regarding the initial value of n and its relevance to the series.
Some participants have offered guidance on applying the Alternating Series Test, while others have noted the importance of specifying the initial value of n in the context of proper notation. Multiple interpretations regarding the significance of the initial value are being explored.
There is a mention that the initial value for n is typically not zero, but this has not been explicitly stated in the problem. The discussion highlights the importance of notation in mathematical expressions.
bfusco
i don't have the slightest clue where to start
Since this is a series and there is an alternating sign in the consecutive partial sums, you should use the Alternating Series Test.
[tex]\sum^{\infty}_{n=?}(-1)^n \frac{(\cos n)^2}{√n}[/tex]
You have not stated the initial value for n.
The first step: Let [itex]a_n=\frac{(\cos n)^2}{√n}[/itex]. Find the limit and test if it's zero.
Second step: Is [itex]a_{n+1}\leq a_n[/itex]?
If both of these conditions are satisfied, then the series converges.
The initial value for n doesn't matter. It's presumably not zero.
The initial value of n is normally ignored, but stating the latter forms part of the proper notation when writing the series with the summation symbol.
