Conversion of distortions in RF waves to Electricity
To convert distortions in RF signals into electrical energy, specific components are needed, including an RF energy harvester, rectifier, and storage system like a capacitor or battery. The efficiency of the conversion process depends on the frequency and strength of the RF signals. Understanding the principles of electromagnetic waves and circuit design is crucial for effective energy harvesting. Practical applications include charging devices such as smartphones. Overall, successful implementation requires knowledge of RF technology and appropriate hardware.
Mr.Robot
So,the thing is i want to convert distortions generated in two RF signals in Electric energy.
Actually i want to store it and then use it. example- Charging my smartphone.
So what will be the basic requirements for me to do so!
https://www.physicsforums.com/search/1686793/?q=rf+energy+harvest&o=relevance
Likes Mr.Robot
Thank You #Bystander :smile:
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
