How is pressure converted to force in a large enclosed surface area?
  • Thread starter Thread starter mjacobs535
    Force Psi
Pressure is defined as force per unit area, and when applied to a large enclosed surface area, the total force can be calculated using the formula F = P * A. In the context of a chamber with a water column of 1.7 inches at high temperatures, the force exerted on the shell can be determined by multiplying the pressure by the total surface area. A larger surface area at the same pressure results in a greater total force, similar to how a larger sail catches more wind. Therefore, the force exerted by a larger cube at 1 psi is indeed greater than that of a smaller cube at the same pressure. Understanding this relationship is crucial for accurately calculating the forces in such systems.
mjacobs535
I have a "process" that creates approx. 1.7" of water column throughout a large enclosed surface area, at temperatures ranging from 1500 to 2250 F. I am trying to show the actual force applied to the shell over a large surface area from the known measurment of pressure. For instance, I have 1.7" water column, at 1560 F, in a chamber approx. 15ft x 10ft x 65ft. how can I show the force applied to the entire shell?
F = P * A
F Force
P Pressure
A Area
NUCENG said:
F = P * A
F Force
P Pressure
A Area
I understand that, what I am trying to understand is, if you have for instance 1 psi in a 12" cube, is the outward exerted force less than that of a 36" cube with 1 psi? It seems that the larger area would have less force than the smaller area at the same pressurization.
F=P*A
Take 2D:
1*(12)^2 = 144 lb of force
1*(36)^2 = 1296 lb of force
Pressure is the result of force over an area. If you have more square inches, you need more pounds.
For 3d just multiply by 6
12" cube pressurized to 1psi has 864 lb of force.
36" cube pressurized to 1psi has 7776 lb of force.
Think of a sailboat. A larger sail area produces more force at the same wind speed. Two containers at equal pressure and different surface areas will produce more force on the container with the larger surface area. The pressures (force per unit area) are the same but the areas are different so the total force is different.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
