Converting square root to perfect square
The discussion revolves around a method for converting the expression √(36 + x²) into a perfect square by substituting x with 3(t - 1/t). The user questions the rationale behind choosing this specific substitution and whether there is a rule governing it. They note that while they understand the overall goal of solving the equation C(x) = [(9-x) + 1.25√(x² + 36)], the substitution process confuses them. The conversation suggests that there may not be a strict rule for this substitution, indicating a more intuitive or exploratory approach to the problem. Ultimately, the focus is on understanding the transformation of the expression into a more manageable form.
cstvlr
Hi,
I have a problem in my book in which they use a method of making sqrt( 36 + x^2 ) a perfect square by simply making x = 3( t - 1/t ) and then we get 9( t + 1/t )^2 by substituting back into sqrt(36 + x^2). My question is that why did the chose 3( t - 1/t ), is there a rule?
thanks in advance.
What were they trying to do with the expression √(36+x2) ? For example, if they were trying to integrate, you could have made a simple trig substitution instead of trying to think of some odd set of functions to string together.
no its in an equation form,
C(x) = [(9-x) + 1.25sqrt( x^2 + 36 )], where C(x) is a function.
and they're trying to solve for x, so they used the method above, and I know how to solve it, but I lost it when they used let x = 3( t - 1/t )
x = 3( t - 1/t ) ⇒ x2 = 9( t - 1/t )2
∴√(36+x2)=√(36+9(t- 1/t)2), how does that turn into an expression like √(a+b)2?
I do not think there rule per se for using that substitution though.
Fair enough, thanks anyway.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
