Converting the Laplacian into polar coordinates
Xyius
I need to convert the Laplacian in two dimensions to polar coordinates.
\nabla^2 u=\frac{\partial^2 u}{\partial x^2}+\frac{\partial^2 u}{\partial y^2}
I am having problems with computing the second derivatives using the chain rule. For example, the first derivative with respect to x would be..
\frac{\partial u}{\partial r}\frac{\partial r}{\partial x}+\frac{\partial u}{\partial \phi}\frac{\partial \phi}{\partial x}
I don't know where to go from here to compute the second derivative. Would I need to use the product rule on each term when differentiating again? By the way, the answer is..
\nabla^2 u=\frac{\partial^2 u}{\partial r^2}+\frac{1}{r}\frac{\partial u}{\partial r}+\frac{1}{r^2}\frac{\partial^2 u}{\partial\phi^2}
Can anyone help me with this??
That should be
\frac{\partial u}{\partial x}=\frac{\partial u}{\partial r}\frac{\partial r}{\partial x}+\frac{\partial u}{\partial \theta}\frac{\partial \theta}{\partial x}~~(1)
Polar coordinates are given in r and θ (theta) rather than r and φ (phi).
And the other partial would be
\frac{\partial u}{\partial y}=\frac{\partial u}{\partial r}\frac{\partial r}{\partial y}+\frac{\partial u}{\partial \theta}\frac{\partial \theta}{\partial y}~~(2)
To get \frac{\partial^2 u}{\partial x^2}
and
take the partial with respect to x of (1), above, and take the partial with respect to y of (2), above. To do this you'll need to use the product rule and the chain rule.
It might be helpful to make a diagram showing the relationship between u, r, θ, and x and y.
Code:
...u
r...θ
x...y
What I'm attempting to show here is that the relationship between u and x involves paths through both r and θ; namely, u to r, then r to x, and also u to θ, and then θ to x.
It's similar for the partial of u with respect to y.
Theta and Phi are just dummy variables, my chain rule isn't less correct because of the fact that I used a different variable. I just happen to like Phi better than theta.
Anyway, I haven't gotten a chance to try this again, as soon as I try it ill report back.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
