Converting Uniform Load to Point Forces on Truss Pin Joints
To convert a uniformly distributed load on a truss into point forces at the pin joints, calculate the resultant force of the distributed load, which typically acts downward at the midpoint joint. This resultant force can be represented as a single force acting in the negative y-direction. Additionally, consider the moments created by the distributed load, as they can be expressed through this resultant force. Each joint will experience both x and y forces due to the load distribution, which can be determined through equilibrium equations. Understanding these concepts is crucial for accurate force analysis in truss systems.
tmglynch
If there is a uniformly distributed load due to gravity on a truss, how do I convert this into point forces on the three pin joints on the truss?
I am having trouble trying to work it out as I'm pretty sure there will be both forces in the x and in the y for each of the joints, but I can't work out how to determine this.
Thanks
Have you tried calculating the resultant force of the distributed force (which by the looks of your drawing will be at the middle joint, in the -y direction) and then calculated the forces in each truss due to the resultant force?
Remember, the moment caused by a distributed force can be expressed as a single resultant force applied at a point.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
