Conveting Mass Into Energy Problem
In summary, the annual energy requirement of the USA is estimated to be 10^20 J and finding a 100% efficient process to convert matter into energy would require approximately 1,111 Kg of material. This amount is equivalent to 3 Kg per day, which is significantly less than the current fuel consumption.
Delzac
389
The annual energy requirement of the USA is of the order [tex]10^20[/tex] J. If we could find a 100% efficient process that could change matter into energy, how many kilograms of material would be needed to meet this requirement?
[tex]E = mc^2[/tex]
Well, i simply sub [tex]10^2^0[/tex] into [tex]E = mc^2[/tex]
And i obtain, [tex]\frac{10^2^0}{(3.0*10^8)^2}[/tex]
then [tex]m=11,111.1111[/tex]
Is this correct? It looks to me like too simple a question, since this is the last question of my tutorial.
It might have just been a question put into make you think about the possible consequences. But there's a slight miscalculation - you're off by one decimal place: ~1,111 Kg. Whats so special about this? Dividing by 365 to get the daily rate, you arrive at the conclusion that to support the energy needs of the USA on a daily basis would require 3 Kg of matter to be completely transformed into energy. Maybe you could compare it to the magnitude of fuel used nowadays? Just food for thought.
K, thanks for the help.
1. What is the equation for converting mass into energy?
The equation for converting mass into energy is E = mc^2, where E represents the energy in joules, m represents the mass in kilograms, and c represents the speed of light in meters per second.
2. How does this conversion occur?
This conversion occurs through a process called nuclear fusion, in which the nuclei of atoms combine to form a new nucleus, releasing a tremendous amount of energy in the process.
3. What is the significance of this conversion?
The significance of this conversion is that it allows for a tremendous amount of energy to be produced from a small amount of mass. This is the basis for nuclear power and is also responsible for the energy produced by the sun and other stars.
4. Can this conversion occur naturally?
Yes, this conversion can occur naturally in the core of stars, where the extreme temperatures and pressures allow for nuclear fusion to take place. It is also believed to occur in certain types of radioactive decay.
5. Are there any potential dangers associated with this conversion?
Yes, there are potential dangers associated with this conversion, particularly in the context of nuclear power. If the process is not carefully controlled, it can result in a nuclear explosion. Additionally, the disposal of nuclear waste from this process is a major environmental and safety concern.
