Convex function on closed interval?
csc2iffy
Let K be the closed interval [0,1] and consider the function f(x)=x^2. Is f convex? Is f linear?
help please :/ i don't even know how to set this up to check, our teacher didn't even get to this in class yet!
What is the definition of a linear function? Does your f(x) satisfy that? What is the definition of a convex function? Does that apply to f(x)? If your teacher has not covered that material yet, is it nevertheless in your textbook? If not, you can use Google, or go to the library.
RGV
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
