Calculating Cooper Pair Density in Niobium/YBCO
In summary, the conversation discussed the possibility of calculating the average number of Cooper pairs per cubic centimeter of niobium or YBCO at their critical temperatures. It was mentioned that the Uemura relation connects the superfluid density to temperature and that the effective mass of the Cooper pairs is not simply double the electron mass, but depends on the band structure. The conversation also touched on the construction of superconducting wires and the percentage of free charge carriers that participate in the supercurrent. It was noted that in high-Tc superconductors, the presence of the pseudogap in the normal state can affect the number of free charge carriers that condense into the superfluid.
Davephaelon
134
Is it possible to calculate the average number of Cooper-pairs, existing at any given moment, per cubic centimeter of niobium (or YBCO), at their critical temperatures? I realize that Cooper pairs form and dissolve continuously, and constantly change partners, so perhaps its not easy to calculate - unless there's some equilibrium value for a given temperature and material.
Yes, at the critical temperature, it is 0.
I think you are asking for the superfluid density. If this is true, then you may want to look up the Uemura relation that connects the superfluid density to temperature. The superfluid density, in turn, is typically defined as the being proportional to ns/m*, where ns is the density of superconducting electrons and m* is their effective mass.
Zz.
DrDu, ZapperZ, thanks for the replies. I gather that if I look up the Uemura relation, there might be tables, someplace on the internet, that shows the actual superfluid density, for a given material at a given temperature.
Is the effective mass "m" of the Cooper pairs simply double the electron mass?
Er.. no. You need to know quite a bit of solid state physics here. The effective mass is the mass of the single-particle electron. It depends on the band structure.
Zz.
I believe I have found the answer to the question I posed above, from this 2003 post: http://www.phys-l.org/archives/2003/02_2003/msg00393.html A typical superconductor, ( at low temperature, when all the mobile electrons are in the superconducting state) , has a current carrying electron density of 10^22 per cubic centimeter (though it's not quite clear from the text whether this is the number of Cooper pairs or individual electrons comprising those Cooper pairs).
That is the total valence electron density of copper.
DrDu, thank you for that clarification. Presumably at a low enough temperature, they all condense into Cooper-pairs.
I remember reading someplace, that the superconducting wire that they use in MRI machines, and other applications, consists of many individual niobium-alloy, (or whatever material they use), strands imbedded in a copper matrix. The reason stated is that the supercurrent flows on a wire's surface, (below the London penetration depth), so that it would be wasteful to have one large superconductor wire, as most of the wire's cross-sectional area, (and presumably most of the valence electrons), would not be carrying current.
I never bothered looking at the piece of niobium-tin superconducting wire I bought under a magnifying lens to see if it was constructed that way. I used to have an old microscope. If I can find it I'll take a look at the ends of my NbTi wire.
Actually, no they don't.
This is painfully obvious in high-Tc superconductors, where the presence of the pseudogap in the normal state has been debated as either being the precursor of superconductivity or competing with superconductivity. It has also been measured that maybe no more than 20% of the free charge carrier actually condenses into the superfluid.
So no, your estimation using that value will be way off! It isn't as easy as you think.
Zz.
ZapperZ,
I noticed that in the paper you linked to that for pure, superconducting metals it seems to be saying that all conduction electrons participate in the supercurrent, in the very first sentence. What confuses me is that a supercurrent flows on the surface (or just below the surface) of a wire. So, for example, if you had a circular cross-section 'wire' of pure niobium that was one inch in diameter, all the current would flow in a thin layer near the surface (when a current is flowing and it's not just a static situation). But if all the valence electrons, throughout the wire, move to the near surface conducting layer, at zero K, and participate in the supercurrent, it seems like there would be a strong charge imbalance within the one inch diameter wire. I suppose if the wire diameter is twice the Cooper pair coherence length, then the electrons in the wire's interior space could participate in the supercurrent without actually being in the near surface layer.
I found a great article about the pseudogap phenomena in high Tc superconductors, which I'll be reading shortly: http://www.science20.com/news_articles/what_pseudogap-77490 I briefly looked at the beginning of it, but will read the rest when I print it out at home.
Could the fact that less than 20% of free charge carriers participate in the supercurrent, in high Tc superconductors, result from the fact that only the copper-oxygen layers are actually involved in conduction?
Related to Calculating Cooper Pair Density in Niobium/YBCO
1. What is the significance of calculating Cooper pair density in Niobium/YBCO?
The calculation of Cooper pair density in Niobium/YBCO is important in understanding the superconducting behavior of these materials. It can provide insights into the critical temperature and critical magnetic field at which superconductivity occurs, as well as the strength of superconductivity in these materials.
2. How is Cooper pair density in Niobium/YBCO calculated?
The Cooper pair density in Niobium/YBCO can be calculated using the BCS (Bardeen-Cooper-Schrieffer) theory, which relates the superconducting energy gap to the pairing potential and the density of states near the Fermi level. This calculation can also be done experimentally using techniques such as tunneling spectroscopy or specific heat measurements.
3. What factors can affect the Cooper pair density in Niobium/YBCO?
Several factors can influence the Cooper pair density in Niobium/YBCO, including temperature, magnetic field, and impurity scattering. As the temperature or magnetic field increases, the Cooper pair density decreases, while impurities can disrupt the pairing of electrons and decrease the density.
4. What is the relationship between Cooper pair density and critical temperature in Niobium/YBCO?
The Cooper pair density and critical temperature in Niobium/YBCO are directly related. As the Cooper pair density increases, the critical temperature also increases, meaning the material can superconduct at higher temperatures. This relationship is described by the BCS theory.
5. How does the Cooper pair density in Niobium/YBCO compare to other superconducting materials?
Niobium/YBCO is a high-temperature superconductor, meaning it can superconduct at relatively high temperatures compared to other materials. Its Cooper pair density is typically higher than that of low-temperature superconductors, but lower than that of other high-temperature superconductors such as cuprates. The exact values may vary depending on the specific material and conditions.
  • Atomic and Condensed Matter
  • Other Physics Topics
