Could a 100% hydraulic system as a vehicle prime mover work?
The discussion centers on the feasibility of a 100% hydraulic system as a vehicle prime mover, exploring theoretical and practical aspects of hydraulic versus electric systems, integration into vehicles, and existing applications. Participants consider performance, component availability, and the implications of using hydraulic systems in various vehicle types.
  • One participant questions which system, hydraulic or electric, would be superior in terms of off-the-shelf components, performance, longevity, and simplicity, assuming an endless power source.
  • Another participant mentions that two-wheel drive motorcycles have successfully utilized hydraulic drive systems.
  • A participant notes that hydrostatic drive vehicles are common, but questions whether the discussion pertains to a different application than typical passenger vehicles.
  • One participant acknowledges that driving the hydraulic pump with a traditional engine is a likely scenario.
  • Another participant points out that while specialized vehicles already use hydraulic systems, the cost of fluid power for smaller vehicles like passenger cars remains a concern.
  • A participant provides detailed specifications for a hydraulic system they considered for their vehicle, including performance metrics and costs.
  • One participant warns that optimizing fluid flow is crucial to prevent heat generation in hydraulic systems.
Participants express a range of views on the practicality and efficiency of hydraulic systems compared to electric systems, with no consensus reached on which is definitively better. The discussion includes both support for and skepticism about the viability of hydraulic systems in various vehicle applications.
Participants discuss the implications of using hydraulic systems in vehicles without resolving the complexities of cost, efficiency, and performance across different vehicle types. The conversation reflects a variety of assumptions about energy sources and system integration.
jettlea
Given: I understand that there would have to be the equivalent energy source to drive the pump. That I will look to later (my gut says the real issue), but for the purposes of this discussion, assume endless power from a source of electricity or hydraulic pressure/flow, and you have to build a system and integrate it into a demonstrable vehicle asap.
Two initial questions:
1. In a perfect world, between an electric prime mover and a hydraulic, which would (in your view) be better vis-a-vis: off the shelf components, performance, longevity, and simplicity.
2. If a hydraulic prime mover is indeed better, could you not simply mount up the motor to the yoke of the differential and achieve the same performance (thereby by-passing the need for a transmission)?
I have been thinking about this for a couple of weeks and am trying to get a handle on this.
Thanks in advance
I have been thinking about this for a couple of weeks and am trying to get a handle on this.Thanks in advance
Welcome to the PF.
I don't know if it helps, but 2-wheel drive motorcycles have been using hydraulic drive for a number of years now:
http://www.gizmag.com/go/2351/
Hydrostatic drive vehicles are very common although I haven't heard of it for regular passenger automotive vehicles. Do you have something different in mind or can I assume you are thinking powering a hydraulic pump with some type of engine (gasoline, diesel, etc.) and then controlling the flow to one or more hydraulic motors (wheel motors, single motor at differential input shaft, etc.)?
Yes, driving the hydraulic pump with another source of energy (diesel, gas, etc.).
Lots and lots of special designed vehicles do all that you propose already. I've worked with and around them for decades. With recent improvements in pump and motor technology, it now seems reasonable for a very large variety of vehicle sizes. The trouble is that for smaller vehicles, like passenger cars, the fluid power is much more expensive than conventional options. But if I have to design a thousand ton crane to lift a load and roll down a rail, I'd have no other reasonable options than fluid power.
Its not 100% but close enough
http://www.cardomain.com/ride/3003264
http://blog.cardomain.com/2008/03/28/ford-explorer-g/
actually I looked into this for my car with these specs,
Speed: 400-4000 rpm (67 rev/sec)
Disp Size: 2pcs 378 cm/rev (29 in^3/rev)
Pressure: 0-276 Bar (0-27Mpa) (0-4000psi) max 5000psi
Flow rate: 809l/min (13.5 L/s)(213gpm) or 1pc 1618 L/min (27 L/sec)(427gpm)
Power: 300kW working (402 Hp working) or 1 pc 745 kw (theoretical) (600kW working)
Torque: 1424Nm (12605 in-lb)(1050 ft-lb)
direction: Bi-directional
material: steel/iron preferred, others optional
type: internal gear positive displacement preferred, others optional
shaft: axial or radial, splined
QTY: 1 or 2
Fluid: Hyd, normal vis.
flange/port: code 62 preferred or at providers discretion
Mounting: suitable
Noise: N/A
Temp: 15-100 degrees C
the quote was $9000-$12000 for each pump
A lot of care would need to be taken to optimize the flow of the fluid or you will just generate heat.
