Could Super Earths have Earth like atmospheres?
  • Thread starter Thread starter willstaruss22
    Earth
Super Earths, with diameters twice that of Earth and eight times its mass, could potentially have atmospheres below 10 bar, depending on factors like temperature and hydrogen availability. The surface gravity of such planets would be around 2g, leading to a pressure of about 2 bar if atmospheric gas amounts are similar to Earth's. The retention of an Earth-like atmosphere may depend on the presence of a magnetic field, which protects against atmospheric erosion from solar wind. Additionally, the geological activity and potential for photosynthetic life are crucial for maintaining a stable atmosphere. Overall, the interplay of gravity, atmospheric composition, and magnetic field strength plays a significant role in the viability of Super Earths' atmospheres.
willstaruss22
I am wondering if a Super Earth planet with 2x Earths diameter and 8x Earths mass could have atmospheres below 10 bar? If so how could they be formed?
Im asking because its theorized that super Earths will have thick hydrogen atmospheres. I was wondering if Super Earths could have thinner atmospheres?
Astronomy news on Phys.org
If they are hot enough, if there is not enough hydrogen, or if all hydrogen formed chemical bonds... why not.
They might be rare.
Surface gravity of a planet with parametres as specified would be 2g.
With the same amount(mass) of atmospheric gasses as on Earth, it'd result in merely 2 bar pressure.
Additionally, there's a lot of variation in pressure possible for any value of surface gravity. Compare Earth and Venus, with similar values of g and almost two orders of magnitude difference in surface pressure.
Lots of Factors
Some thoughts:
  • The more massive world, with a deeper potential well, is maybe going to hang onto some gases that Earth lost. If it's only twice the mass of Earth then probably not a lot more, but maybe extra water, at least.
  • How deep that potential well will be isn't a trivial question because you have to know how much rock and metal compresses under increased gravity.
  • It's hard to imagine having even a vaguely earthlike atmosphere without plenty of photosynthetic life.
  • Even if the pressure is high at sea level there will be places at high altitude where the pressure is more earthlike - and increased gravity means a thinner atmosphere, so the altitude doesn't need to be all that high.
  • The chains of logic can be complex. If I understand correctly: Venus is hot, so Venus loses its water from its surface, so plate tectonics stops, there's not much weathering, nothing absorbs the CO2, greenhouse effect makes it get hotter, etc..
  • Last time I looked into this I found an elementary planetology lecture notes series on the web. It wasn't hard and that was years ago. Should be even easier now.
The problem with super Earth's is the greenhouse effect. Yes, it will trap more atmosphere - and more heat. It would need to be in a 'goldilocks' zone to avoid the fate of Venus, or death by freezing. A planet like Earth walks a tightrope to remain biologically viable for billions of years
Atmosphere on super Earth's
I think we may be missing one thing here. Earth has a magnetic field of sufficient strength to protect the atmosphere from being eroded by the solar wind. Without that field, our planet would probably be much less inviting for life...so I would have to presume that some kind of magnetic field, probably from a molten iron core revolving, would have to be part of the equation for atmosphere retention...so if a super Earth manages to not have a molten iron core, it might not be able to prevent rapid (comparatively) loss of the atmosphere. Mars has plenty of iron, but I suspect it is locked up in oxides that are solid, and has no molten, moveable core and therefore no magnetic field generating...so combined with less gravity, any atmosphere was driven away. Venus is probably a special case, but I would love to see if there is any high rate erosion of the atmosphere due to it's lack of a magnetic field...
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
Today at about 4:30 am I saw the conjunction of Venus and Jupiter, where they were about the width of the full moon, or one half degree apart. Did anyone else see it? Edit: The moon is 2,200 miles in diameter and at a distance of 240,000 miles. Thereby it subtends an angle in radians of 2,200/240,000=.01 (approximately). With pi radians being 180 degrees, one radian is 57.3 degrees, so that .01 radians is about .50 degrees (angle subtended by the moon). (.57 to be more exact, but with...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
