physmania
- 3
Two small spheres of 15 g each are suspended from a common point by threads of length 35 cm. Each thread makes an angle with the vertical of 20 degrees. Each sphere carries the same charge. Find the magnitude of this charge.
F=(kq1q2)/r^2
Well I basically found out the force from each ball from F = mg, than I found out the distance between them with trigonometry which was 23.94 cm.
I then plugged this into the equation to get:
0.147 = kq^2/(23.94^2).
I understand why this is wrong as this force is not the force between the two... I am a bit stuck on how you work backwards with this question so you get the force between the two first.
