Counterexample for a premeasure on a semiring over Q
  • Thread starter Thread starter variety
    Counterexample
variety
Let \alpha(r)=r and let P be the family of intervals [a,b) in \mathbb{Q}. Define \mu_{\alpha}([a,b))=\alpha(b)-\alpha(a). Show by example that \mu_{\alpha} is not countably additive.
\mu is countably additive if for any sequence of mutually disjoint subsets E_1, E_2, ... such that \bigcup_{i=1}^{\infty}E_i\in P, we have \mu\left(\bigcup_{i=1}^{\infty}E_i\right)=\sum_{i=1}^{\infty}\mu(E_i).
This problem is driving me insane. I know I have to somehow use the incompleteness of the rationals, so I tried to use sequences which I know do not converge in \mathbb{Q}. For example, I tried defining x_{n+1}=x_n + 1/n^2 and E_n=[x_n,x_{n+1}), where x_1=0. Then \mu(E_n)=1/n^2, so \sum_{i=1}^{\infty}\mu(E_i)=\pi^2/6, which is not in \mathbb{Q}. But this does not work because \bigcup_{i=1}^{\infty}E_i=[0,\pi^2/6)\notin P.
Basically I keep running into two problems. Either this happens, or I find a sequence whose union is in P but \mu is countably additive. Any hints or suggestions would be greatly appreciated.
The hint is that you need to use not only the incompleteness of the rationals, but also the fact that they have measure zero. That is, for every epsilon>0, it is possible to cover Q by countably many intervals s.t the sum of their lengths is less than epsilon. That's because Q is countable. Thus, these intervals will have union [0,1)\capQ, but the sum of their measures will be as small as you like.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
