Couple light into photonic crystal fiber
The discussion revolves around the challenges of coupling light into a hollow core fiber with a 20µm core and a numerical aperture of 0.03, using a Ti:Sapphire laser with a spot size of 2-2.5mm and a 50mm focal length. The user reports achieving only 6µW of power and seeks suggestions for improvement. A participant asks for more details about the fiber, specifically its design and loss characteristics at the laser wavelength. The conversation highlights the importance of understanding the fiber's specifications to diagnose the low power coupling issue. Additional information, such as a cross-section image and loss data, is requested to provide better assistance.
jlyu
I have one hollow core fiber, the core is around 20um, Numerical Aperture is
0.03. The spot size of Ti:Sapphire laser is around 2~2.5mm. So I used focal
length 50mm. But only very few power can be achieved (6uw). I wonder
the reason. Could someone please give me some suggestions?
Hi There,
Maybe I can help you. Can you give a bit more information about the fiber you have? A 20µm core for a 800nm range hollow-core fibers sounds very big. Do you know if this is a 7 or a 19 cell design?
/Kim Hansen, NKT Photonics
Actually, I do not think it belongs to 7 or 19 cell design. :frown: It is made by some other research group.
No worries. We would be happy to help even if the fiber is not made by us. Do you have a picture of the cross section of the fiber? Also, do you know what the loss in the fiber is at your laser wavelength?
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
