A Covariance of equal time commutation relations
Betty
I have a question regarding the covariance of the equal time commutation relations in relativistic quantum field theory. In the case of a scalar field one has that the commutator is (see Peskin, pag. 28 eq. (2.53) )
$ [\phi(0), \phi(y)] = D(-y) - D(y) $
is an invariant function, which is zero outside the light cone.
The commutator between the field and the conjugate momentum is
$[\phi(0), \pi(y)] = [\phi(0), \dot \phi(y)] = \partial_{y^0} [\phi(0), \phi(y)] , $
which also implies that $ [\phi(0), \pi(y)] = 0 $ outside the light cone. The equal time commutation rules which lead to second quantization read
$[\phi(0), \pi(y)] = \partial_{y^0} [\phi(0), \phi(y)] = i \delta^3(\vec{y})$ for $ y^0 = 0 $.
However this point seems to me a little bit odd, since this relation, being expressed as the derivative of an invariant quantity, is not invariant. This is also confirmed by the fact that the $\delta^3$ is also not invariant. Therefore, I wonder how we get a covariant theory starting from second quantization rules which are not invariant, or why this fact does not lead to any contradiction.
You might want to fix your latex. Use two hashes or two dollar signs.
Likes Demystifier
Thank you for your comments. I had a look to Eq. (13) in http://de.arxiv.org/abs/hep-th/0202204 and this (the result of (13) shouldn't be $$ i \chi(x)/\sqrt(g_{00})$$ ?) just confirms that the formulation of the equal time commutation relations depends on the choice of $$ \Sigma $$. Even if one expresses the relation in an invariant form as $$n^\mu \partial_\mu [\phi(0),\phi(x)] = i \frac{\delta(x)}{\sqrt{g_{00} g^3}}$$ the quantity on the r.h.s. is not an invariant unless $$ g_{0i}=0$$.
There is some other reference where this topic is treated more in detail?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
