Covariant derivative transformation
faklif
The problem concerns how to transform a covariant differentiation. Using this formula for covariant differentiation and demanding that it is a (1,1) tensor:
<br /> \nabla_cX^a=\partial_cX^a+\Gamma^a_{bc}X^b<br />
it should be proven that
<br /> \Gamma&#039;^a_{bc}=<br /> \frac{{\partial}x&#039;^a}{{\partial}x^d}<br /> \frac{{\partial}x^e}{{\partial}x&#039;^b}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> \Gamma^d_{ef}<br /> -<br /> \frac{{\partial}x^d}{{\partial}x&#039;^b}<br /> \frac{{\partial}x^e}{{\partial}x&#039;^c}<br /> \frac{{\partial}^2x&#039;^a}{{{\partial}x^d}{{\partial}x^e}}<br />
<br /> \partial&#039;_cX&#039;^a=<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}\frac{\partial}{{\partial}x^f}<br /> (<br /> \frac{{\partial}x&#039;^a}{{\partial}x^d}X^d<br /> )=<br /> \frac{{\partial}x&#039;^a}{{\partial}x^d}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> \frac{\partial}{{\partial}x^f}<br /> X^d<br /> +<br /> \frac{{\partial}^2x&#039;^a}{{\partial}x^f{\partial}x^d}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> X^d<br />
<br /> X^d<br /> =<br /> \frac{{\partial}x^d}{{\partial}x&#039;^b}<br /> \frac{{\partial}x&#039;^b}{{\partial}x^d}<br /> X^d<br /> =<br /> \frac{{\partial}x^d}{{\partial}x&#039;^b}<br /> X&#039;^b<br />
<br /> X^e<br /> =<br /> \frac{{\partial}x^e}{{\partial}x&#039;^b}<br /> X&#039;^b<br />
I thought I'd simply look at the primed coordinates from two directions and that that should do it... didn't quite happen as planned though.
In primed coordinates
<br /> \nabla_cX^a&#039;<br /> =<br /> {\partial}&#039;_cX&#039;^a<br /> +<br /> \Gamma^a_{bc}&#039;X&#039;^b<br />
Transformed using the equations under 2.
<br /> \nabla_cX^a&#039;<br /> =<br /> \frac{{\partial}x&#039;^a}{{\partial}x^d}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> \frac{\partial}{{\partial}x^f}<br /> X^d<br /> +<br /> \frac{{\partial}x&#039;^a}{{\partial}x^d}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> \Gamma^d_{ef}X^e<br /> =<br /> {\partial}&#039;_cX&#039;^a<br /> -<br /> \frac{{\partial}^2x&#039;^a}{{\partial}x^f{\partial}x^d}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> X^d<br /> +<br /> \frac{{\partial}x&#039;^a}{{\partial}x^d}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> \Gamma^d_{ef}X^e<br /> =<br /> {\partial}&#039;_cX&#039;^a<br /> -<br /> \frac{{\partial}^2x&#039;^a}{{\partial}x^f{\partial}x^d}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> \frac{{\partial}x^d}{{\partial}x&#039;^b}<br /> X&#039;^b<br /> +<br /> \frac{{\partial}x&#039;^a}{{\partial}x^d}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> \Gamma^d_{ef}<br /> \frac{{\partial}x^e}{{\partial}x&#039;^b}<br /> X&#039;^b<br />
So my thought was that anything related to X'^b would be the what I seek which gives
<br /> \Gamma&#039;^a_{bc}=<br /> \frac{{\partial}x&#039;^a}{{\partial}x^d}<br /> \frac{{\partial}x^e}{{\partial}x&#039;^b}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> \Gamma^d_{ef}<br /> -<br /> \frac{{\partial}x^d}{{\partial}x&#039;^b}<br /> \frac{{\partial}x^f}{{\partial}x&#039;^c}<br /> \frac{{\partial}^2x&#039;^a}{{\partial}x^f{\partial}x^d}<br />
This i kind of close but it's different in the last part where I have f:s instead of e:s. I would really appreciate some help, I've been stuck for a long time.
Hi faklif! :smile:
Do you mean you're worried about having ∂xf and /∂xf instead of ∂xe and /∂xe ?
They're "dummy variables" … it doesn't matter what they are! :wink:
tiny-tim said:
Hi faklif! :smile:
Hi and thank you!
Now that I think some more about it (should have done that before spending the better part of the weekend :wink:, having to much spare time makes me stupid...) it makes sense. For a given a,b,c you'd still get the same implied summations. Thanks again for rescuing my monday!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
