How Do I Delete a Thread on a Website or Forum?
latentcorpse
Edit: Solved
Don't know how to delete thread though!
A covariant derivative is an example of a derivation, that is a differential operator that satisfies the Leibnitz (product rule):
D ( v \otimes w ) = (Dv)\otimes w + v \otimes (Dw).
Therefore the part that you proved above follows. Now, since l^2 is a scalar, it's covariant derivative reduces to the ordinary derivative. You can see this by explicit computation, since the signs in front of the Christoffel symbols are opposite when acting on covariant and contravariant vectors.
Judging from a textbook's perspective, your problem is ill-posed, because the l^2 for l a 4-vector is a genuine scalar, and the way the covariant derivative acts on the scalars is used as an axiom in deriving how the covariant derivative acts on covectors, knowing how it acts on scalars and 4-vectors.
latentcorpse said:
Edit: Solved
You don't delete your post after you receive help here. Check your PMs.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
