Calculating Radius of Crater from Meteor Impact
When a stellar object impacts the Earth, it creates a crater influenced by the object's mass, velocity, and the type of ground at the impact site. The kinetic energy of the object must be dissipated upon impact, affecting the crater's size and shape, which does not correlate linearly with energy. The discussion highlights that the impact velocity for meteors typically ranges from 10 to 70 km/s, with an example of the Barringer Crater illustrating that a 50-meter diameter nickel/iron meteor traveling at approximately 11 km/s produced a crater of about 1.2 km. The composition of the meteor and the ground type also play significant roles in determining the crater size. Understanding these dynamics is essential for accurately modeling crater formation.
ChrisVer
When a stellar object falls into the Earth's surface, it creates a crater on the ground.
Most of the times, when people refer to these things, they refer to their age and their diameter/radius. My question is mainly about the radius. Is there a dynamical way to solve for the shape and radius of a crater such an impact can cause?
Eg if I said that a meteor of mass 0.001 the mass of the earth, and initial velocity of 200 km/s falls horizontally on the ground, would I be able to calculate the radius of the crater?
Well, you know the mass and the velocity, so you can start by calculating the kinetic energy of the steller object. This energy will have to be dissipated upon impact ( upon impact there is a horizontal and vertical component to the velocity of the object ). The heat produced will liquify and/or vaporizie some, or all of the object and some of the earth. Correlation between the initial kinetic energy and size of the crater produced most likely does not follow in a linear fashion.
You're wanting to model a glancing/grazing impact? Of an object a tenth of Earth's diameter? Trajectory of COM is tangent to Earth's surface? Cuts a chord 0.1 Earth radii below the surface, passes 0.1 radii above the surface?
You might have meant .001 Earth diameter?
oops...I wrote horizontally, I meant vertically (like a falling apple)
The ground type at the impact site would also have an effect on the crater size produced
solid rock is likely to produce a smaller crater than soft ground for a given size meteorite impact
Also the type of meteor ... nickel/iron or rocky ( chondrite) and its velocity at impact
also let's get you velocity into a better range ---- 10 - 70km/s is the avg range for meteors entering the atmosphere
your 200 km/s is a bit high
its estimated that the meteor that produced the Barringer Crater in Arizona was still traveling at ~ 11 km/s when it impacted
This was a ~ 50 metre diameter nickel/iron type and produced a crater of about 1.2 km in diameter
Dave
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
