Crazy physics problem (big debate in my high school)
47 replies · 19K views
I did model this using excel accurate to the second, i came out with the correct veloctiy at moment of impact, with gravity equal to 9.81 (like it should be) at moment of impact, with a time of 27916 seconds or about 7.75 hours. Ill post the excel spreadsheet in a little bit I am trying to crunch it down so the file size isn't insanely large ( the spreadsheet comes out to almost 30000 rows!)
I think our answers agree, if I were to make it end at one earth-radius.
Yeah I am sure they do, i finally uploaded the excel spreadsheet as a zip file, its VERY LARGE! and may take your computer a large amoutn of time to open, depending on comp.
http://www.youshare.com/view.php?file=VariableGravityField.zip
You can enter the initial values in the first row and itll work out everything else automatically.
awvvu said:
How do you input something like this into Mathematica? I tried:
DSolve[x''[t] == -GM/x[t]^2, x[t], t]
I don't use DSolve generally.. it doesn't solve many problems. See.. we got this:
[tex] v = \sqrt{2} \sqrt{\frac{GM + rY}{r}}[/tex]
[tex] \frac{dr}{dt} = \sqrt{2} \sqrt{\frac{r}{GM + rY}}[/tex]
[tex] \sqrt{\frac{r}{GM + rY}}dr = \sqrt{2} dt[/tex]
This is what I integrated in Matematica using:
Code:
Integrate[Sqrt[(r)/(G M + r Y)], r]
After a lot of battling with equations and a few mountain dews later.. I've arrived at a solution.. which i believe is quite correct. So.. i request you to please take a look and point out flaws [if any]:
Assumptions for this problem: Take for any arbitrary distance 'r' from the center, let the center be the origin.
Also, instead of taking the starting position as [itex]10R_E[/itex], I'm assuming an arbitrary position 's'.
The acceleration of the object is given by:
[tex] a = -\frac{GM}{r^2}[/tex]
[tex] \frac{dv}{dt} = -\frac{GM}{r^2}[/tex]
[tex] \frac{dv}{dr} \frac{dr}{dt} = -\frac{GM}{r^2}[/tex]
[tex] vdv = -\frac{GM}{r^2}dr[/tex]
[tex] \frac{v^2}{2} = \frac{GM}{r} + C[/tex]
also, at [itex]r = s[/itex], [itex]v = 0[/itex] Hence,
[tex] GM + sC = 0[/tex]
[tex] C = -\frac{GM}{s}[/tex]
So, we have:
[tex] v = \sqrt{2GM} \sqrt{\frac{1}{r} - \frac{1}{s}}[/tex]
Let, us just take out the [itex]\sqrt{2GM} = \Phi[/itex]. We'll call it the 'planetary mass factor' [yup.. it's my turn now to use fancy terms :P], So, we have the 'planetary mass factor' as:
[tex] \Phi = \sqrt{2GM}[/tex]
so..
[tex] \frac{dr}{dt} = \Phi \sqrt{\frac{1}{r} - \frac{1}{s}}[/tex]
let the above equation be eqn. 1.
[tex] \sqrt{\frac{sr}{s - r}}dr = \Phi dt[/tex]
Let,
[tex] \frac{sr}{s - r} = x[/tex]
[tex] \frac{s^2}{(s - r)^2}dr = dx[/tex]
Putting the values in eqn. 1, we get:
[tex] \frac{(s - r)^\frac{3}{2}}{s^2}dx = \Phi dt[/tex]
Also, from the first assumption,
[tex] r = \frac{sx}{s + x}[/tex]
So,
[tex] \frac{dx}{s + x} = \Phi dt[/tex]
[tex] log_e|s + x| = \Phi t + J[/tex]
J is again, a constant of integration. Now, substituting the value of 'x' in terms of r, we get:
[tex] \frac{s^2}{s - r} = e^{\Phi t + J}[/tex]
[tex] \frac{s^2}{s - r} = e^J e^{\Phi t}[/tex]
[tex] \frac{s^2}{s - r} = ke^{\Phi t}[/tex]
On simplifying it a bit,
[tex] r(t) = s\left(1 - \frac{s}{ke^{\Phi t}}\right)[/tex]
Now, r(0) = s . Solving for 'k',
[tex] k = 2s[/tex]
Putting it in the equation, we get the answer as:
[tex] r(t) = s\left(1 - \frac{1}{2e^{\Phi t}}\right) = s\left(1 - \frac{1}{2e^{\sqrt{2GM} t}}\right)[/tex]
This is the equation of motion I got. :D
<snip>
[tex]r(t) = s\left(1 - \frac{1}{2e^{\Phi t}}\right) = s\left(1 - \frac{1}{2e^{\sqrt{2GM} t}}\right)[/tex]
I don't think this is correct- GM has units of L^3/T^2, so [tex]\sqrt{2GM}t[/tex] is not dimensionless. Not sure where the initial error occurs...
The integration looks wrong, in mathematica:
F[r_] = Expand[Integrate[(1/r - 1/s)^(-1/2), r]]
[tex]-\frac{1}{2} \tan ^{-1}\left(\frac{\sqrt{\frac{1}{r}-\frac{1}{s}} (2 r-s) \sqrt{s}}{2 (r-s)}\right) s^{3/2}-r \sqrt{\frac{1}{r}-\frac{1}{s}} s[/tex]
Ok, people have tried excel, mathematica, maple...
I tried Python, pure and simple. No Runge-Kutta methods or anything, just pure dv = a*dt and dx = v*dt ...
I got the following results:
Final Velocity = 10607.0 m/s
Total Time Taken = 27943.16 seconds
Actual Final Velocity (from formula) = 10607.1 m/s
I think these confirm the earlier answers... I admit that trying to find the analytical solution is a much more interesting job ;)
What about my effort on page 2? Anyone bother to go over that?
I should've noticed it, gspeechc... I have been thinking along the exact same lines during the last hour. I'm too tired to develop it now, but I think that expression [ dx/ (lot of stuff) ] does have an anti derivative...
You made a mistake there, "x-10" should be replaced by x*10 (when cross multiplying R/x - 1/10) . I have been trying to get an expression substituting 10*R - x = z^2 (or -z^2 ... I haven't worked out the signs yet). Anyway, with such a subtitution, I find it becomes a solvable integral. Either that or I have made mistakes (more probable, that).
In general,
[tex] \Delta t = \int_{r_i}^{r_f}\frac{dr}{v(r)}[/tex]
where [itex]r_i[/itex] and [itex]r_f[/itex] are the initial and final distances and [itex]v(r)[/itex] is the velocity (dr/dt) expressed as a function of r.
Combining conservation of energy and gravitational potential energy expressions yields an expression for velocity in terms of radial distance:
[tex] v^2-v_0^2 = 2GM\left(\frac 1 r - \frac 1 {r_i}\right)[/tex]
Here the velocity is negative (r is decreasing) until the object hits the Earth and the initial velocity is zero. Thus
[tex] v = -\sqrt{2GM}\sqrt{\frac{r_i-r}{r \, r_i}}[/tex]
Applying this result to the initial integral (note the change in integration order to accommodate the negative velocity):
[tex] \Delta t = \frac 1 {\sqrt{2GM}} \int_{r_f}^{r_i}\sqrt{\frac{r \, r_i}{r_i-r}} \; dr[/tex]
Using the the substitution [itex]r=r_i\sin^2\phi[/itex] ([itex]\phi = \sin^{-1}\surd{\frac r {r_i}}[/itex]) and defining [itex]\kappa\equiv r_f/r_i[/itex],
[tex] \Delta t = \sqrt{\frac {r_i^3} {2GM}}<br /> \int_{\sin^{-1}\surd{\kappa}}^{\pi/2}2\,\sin^2\phi \; d\phi[/tex]
from which
[tex] \Delta t = \sqrt{\frac {r_i^3} {2GM}}<br /> \left(\sqrt{\kappa(1-\kappa)} + \cos^{-1}\surd{\kappa}\right)[/tex]
With [itex]r_i=63781.37\,\text{km}[/itex], [itex]GM_e = 398600.4418\,\text{km}[/itex], and [itex]\kappa = 1/10[/itex], the above evaluates to 7.7628 hours = http://www.google.com/search?hl=en&...^2))*(sqrt(0.09)+acos(sqrt(0.1)))+in+seconds". (Link to Google calculator result highlighted)
absolute gem.. priceless. Great work!
and yes.. my method is wrong. The integration I did is wrong.. as pointed by a member in a previous post than this. Also, it is wrong for obvious reasons:
i] [itex]\sqrt{2GM}t[/itex] is used in exponentiation and is not dimensionless [pointed by Andy Resnick]
ii] The equation suggests that the object will gradually move slower.. whereas it should gradually move faster.
I did a really stupid mistake in my integration. While writing down.. i did not copy the 3/2 power and hence it came out as a simple equation derivate of Log[f[x]]...
D H said:
In general,
This equation seems pretty useful. Where's it derived from?
That is the 'definition' of velocity:
[tex] v = \frac{dr}{dt}[/tex]
Oh, doh.
from which
Just to stave off questions:
First, the parameter [itex]\phi[/itex] is obviously in the range[itex][0,\pi/2][/itex]. Phi starts at pi/2 at the release point and would drop to zero at the center of the Earth if the Earth's surface didn't stop the object first.
I integrated [itex]2\,\sin^2\phi[/itex] is done by the means of the identity [itex]2\,\sin^2\phi=1-\cos(2\,\phi)[/itex], yielding [itex]\phi-1/2\sin(2\,\phi)[/itex]. Evaluating wrt the limits leads to (phi part first) [itex]\pi/2-\sin^{-1}\surd\kappa[/itex]. This simplifies to [itex]\cos^{-1}\surd\kappa[/itex] via the [itex]\cos^{-1}x+sin^{-1}x = \pi/2[/itex]. To evaluate the sine term I used [itex]\cos(\sin^{-1}x) = \sqrt{1-x^2}[/itex] for [itex]x\in[0,\pi/2][/itex].
I got it till the integration, and then made another substitution which didn't seem to yield a right answer... that teaches me to neglect trigonometric substitutions! ;)
That methods of yours really is a gem, DH. Especially the way you handled the phis and the kappas ;).
