What is the equation of the tangent plane to a surface at a specific point?
  • Thread starter Thread starter Pengwuino
The equation of the tangent plane to the surface 7z + 7 = x(e^y)cos(z) at the point (7,0,0) is derived using the formula z = f(a,b) + fx(a,b)(x-a) + fy(a,b)(y-b). At the specified point, the function value f(7,0) is 7, with partial derivatives fx(7,0) equal to 1 and fy(7,0) equal to 0. Substituting these values into the tangent plane equation yields z = x. This indicates that the tangent plane is aligned along the x-axis. The final result confirms that the tangent plane equation is z = x.
Pengwuino
Ok i need a lil help here.. i got this question I am not sure how to do
Find the equation of the tangent plane to the surface 7z+7=x(e^y)cos(z) at the point (7,0,0). Any know this?
The equation of the plane is x=0...(the plane yOz)...
Compute the normal vector to the surface in the point (0,0,7).Show it is \vec{i}.
Daniel.
The equation of the tangent plane to a surface at a specific point is given by the formula:
where f(a,b) is the value of the surface at the point (a,b) and fx(a,b) and fy(a,b) are the partial derivatives of the surface with respect to x and y at the point (a,b), respectively.
In this case, we are given the surface 7z+7=x(e^y)cos(z) and the point (7,0,0). We can find the partial derivatives by taking the derivative of the surface with respect to x and y:
fx = e^y*cos(z)
fy = -x*e^y*sin(z)
At the given point (7,0,0), we have:
f(7,0) = 7(0) + 7 = 7
fx(7,0) = e^0*cos(0) = 1
fy(7,0) = -7*e^0*sin(0) = 0
Substituting these values into the formula for the tangent plane, we get:
z = 7 + (1)(x-7) + (0)(y-0)
or simply,
z = 7 + x - 7
z = x
Therefore, the equation of the tangent plane to the surface 7z+7=x(e^y)cos(z) at the point (7,0,0) is z = x.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
