Creating a table from a system of linear equations
To create a table from the given prescription for vitamin C and D, the problem can be approached by setting up a system of linear equations using three variables representing the amounts of each liquid. The liquids contain different percentages of vitamins, which need to be converted into grams to relate to the required daily intake. By defining the variables as grams of each liquid, the amounts of vitamins can be expressed in terms of these variables. This method allows for the formulation of equations that can be solved to find the possible combinations of liquids that meet the prescription requirements. Ultimately, this setup will facilitate the creation of a comprehensive table of combinations.
armolinasf
A doctor's prescription calls for a daily intake of liquid containing 40mg of vitamin c and 30mg of vitamin d. There are three liquids that can be used: one contains 20%vitamin c and 30% vitamin d; the second, 40% vitamin c and 20% vitamin d; the third, 30% vitamin c and 50% vitamin d.
Create a table showing the possible combinations that could be used to fill the prescription.
I'm not quite sure how to approach this one. I'm thinking of setting it up as a system of linear equations with three variables. I'm having trouble relating the percentages to the amount in grams. Thanks for the help.
That sounds like a good idea. The three variables you would use (let's call them x, y, z) would then correspond to the amount of liquid you take from each of the three types.
I would choose grams as units for x, y, z; so for example x = 120 corresponds to taking 120 g of liquid one. Then you can easily express the amount of vitamins in terms of x, y and z and draw up your system of equations.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
