Current amplification without external sources
Amplifying current from 300mA to 600mA without external sources is not feasible due to the conservation of charge principle. To achieve a higher current output, either a different solar panel with a higher current rating or an increase in voltage is necessary. Lowering voltage from 6V to 5V could reduce overall power output, making it unlikely to reach the desired current. External factors such as weather and panel positioning can also impact the actual current output. Ultimately, current amplification requires additional energy sources or alternative circuit designs.
chetan1oct93
i want to amplify my current from 300mA to 600mA. i m making a solar charger and the specifications say 6v 400mA. however i m unable to receive 400mA.. is there a way to amplify current to 600mA from 300mA.. i can lower my volt to 5V from 6V. i don't want to use any external dc or ac supply
No there isn't.
If you want to create 600 mA you must find a combined 600 mA from your circuit. If the only thing you can get out your solar charger is 300 mA, then all you can get is 300 mA.
Think conservation of charge. If you have 300 mA running into your "black box" but 600 mA running out, then your "black box" is somehow magically creating charge. So you would need external circuitry to create a current amplification.
i know that conservation of charge principle.. i m asking for a circuit which can convert me voltage to current somehow... decrease my volts from 6 to 5 and increase current... i increased my current from 30mA to 300mA somehow using other circuitry.. but i want further increase
You won't get more Volts times Amps (Watts) out, whatever you do. The only suggestion is to use an inverter to produce 3V @ 600mA, if you already can supply 300mA at 6V. This is for an ideal inverter, with no losses. In reality, with such low voltages involved, I doubt that you'd get more than 60% of what you put in.
This is a case of "If I were you, I wouldn't start from here", I'm afraid. You either need a different set of PV cells or design a different device to use the volts and current that the ones you have can supply.
How have you managed to increase your current from 30mA to 300mA? Was it by going from series to parallel with your PV array? That implies you must have started with a 60V array (??). If this is the case, you may be able to design a more efficient switched mode supply, based on the 60V supply that will give the current output you want - but you still won't get more Watts out than you put in.
I would first like to clarify that current amplification without external sources is not possible. Current amplification requires an external source of energy to increase the flow of current. In the case of a solar charger, the solar panel is the external source of energy that converts sunlight into electrical energy.
In order to achieve a current of 600mA, you will need to increase the voltage or use a different solar panel with a higher current output. Lowering the voltage from 6V to 5V will decrease the overall power output and may not be sufficient to reach 600mA.
It is also important to note that the specifications for the solar charger may not be achievable in all conditions. Factors such as weather, angle of the solar panel, and shading can affect the actual current output. It may be necessary to adjust your expectations and consider using a higher capacity solar panel or a combination of multiple solar panels to reach the desired current output.
In summary, current amplification without external sources is not possible. To achieve a current of 600mA, you may need to increase the voltage or use a different solar panel with a higher current output. It is also important to consider external factors that may affect the actual current output of the solar charger.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
