How Do You Calculate Charge and Electrons for a Hair Dryer Drawing 9.7 A?
  • Thread starter Thread starter aznangelcakes
    Current Resistance
To calculate the charge passing through a hair dryer drawing 9.7 A in 3.5 minutes, one must understand the relationship between current, charge, and time. The charge can be calculated using the formula Q = I × t, where Q is charge in Coulombs, I is current in Amperes, and t is time in seconds. Additionally, to find the number of electrons, divide the total charge by the charge of a single electron (approximately 1.6 x 10^-19 Coulombs). Understanding these basic concepts is crucial for solving the problem. If illness affects homework submission, requesting an extension from the teacher is advisable.
aznangelcakes
A hair dryer draws a current of 9.7 A.
(a) How much charge passes through the hair dryer in 3.5 min?
C
(b) How many electrons does this represent?
electronsi am sick and i have the homework due tomorrow so i really have no idea how to do it.
That you don't know how to do a shows a serious lack of understanding of a concept like current. So I suppose that you first read your text or my post here so that you know what you are talking about. Hopefully you will then see that a) is extremely easy, once you get the definitions right.
Look at the units of an Ampere.
Look at the charge per electron in Coulombs.
These are very basic questions to see if you understand the meanings of the quantities. If you understand then the solution is relatively obvious. Look up the definition of units of current in your textbook.
yup thanks compu chimp i get it now :)...ive been sick for a week fyi ><
Being sick is annoying (apart from the fact that you're not feeling well for a while, of course), because you have to catch up with a lot of material.
BTW, if sickness prevents you from handing in your homework in time, you can always ask your teacher to grant you a delay.
