Current in secondary of transformer
In an ideal transformer with a turn ratio of one, the voltages in the primary and secondary are equal. When the secondary is connected to a high impedance load, such as an oscilloscope, there may be no current flowing in the secondary. This absence of current means that no power is transferred to the secondary, as power transfer requires a load to draw current. The energy remains in the magnetic field without being utilized. Thus, in this scenario, the transformer does not transfer power to the secondary circuit.
codems5
I am trying to get a better understanding of transformers. Assuming the transformer is ideal, and the secondary is connected to a high impedance load such as an oscilloscope, would there essentially be no current in the secondary?
In this case the turn ratio is one. So ideally, the voltages would be equal. However, if there is no current in the secondary, what is happening to the power that is transferred to the secondary? Does it just remain in the magnetic field? Thanks
Correct.
No, it is still given by the physical turns ratio n.
No, the secondary EMF is V_2=nV_1 as usual. Faraday's law specifies the EMF generated in a loop by changing flux. Secondary current flow depends on load resistance, and may be absent as it is in this case.
There is no power transferred to the secondary, so no power drawn by the primary in your case of an ideal lossless transformer.
Likes 1 person
By saying "in this case", I meant the transformer I am working with has a turn ratio of one and thus the voltages would be equal. Sorry for the confusion. However, you answered the rest of my questions. thank you
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
