Current through Voltage in a Transfer Function
The discussion centers on the calculation of the transfer function for a circuit involving two diodes and resistors. The key issue raised is the professor's application of Kirchhoff's Current Law (KCL) at the output node, which seemingly neglects the output current (Iout) flowing to Vout. The participant questions why this current is disregarded in the analysis, suggesting that it complicates the understanding of the transfer function. They emphasize that the inquiry is relevant to any two-port network configuration with input and output voltages. Clarification on this point could enhance the accuracy of the transfer function calculation.
KasraMohammad
I am trying to solve the transfer function of a circuit. I noticed in the explained notes provided by the teacher, he deduced certain IV characteristics using KCL. The KCL on the node attached to Vout did not consider the output current running to Vout, and instead only incorporated the currents of the remaining three wires attached to that node. Why is this? Do you disregard when calculating transfer function that there is current running to Vout?
It'll be a lot easier if you provide a diagram.
I don't have a diagram of it, but i can explain the circuit, though my question would be equally applicable to any two-port network that has Vin and Vout.
Its a Vin in series with the following in order of closest to Vin: Diode(1) + Diode(2)||Resistor(1) + Resistor(2). Vout is the node between Diode(2)||Resistor(1) and Resistor(2).
When taking the KCL of the node attached to Vout, the professor's notes did not take into account the current Iout, the current running out of that node towards Vout.
I hope my explanation makes sense.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
