Minimum Current for Magnetic Levitation: Is It Safe for a Magician's Act?
To estimate the minimum current needed for a magician to suspend a current-carrying wire using Earth's magnetic field, one must consider the wire's linear mass density of 10g/m and the magnetic field strength at the equator. The force on the wire can be calculated using the equation dF=IdlxB, where the cross product represents the interaction between the current and the magnetic field. Participants in the discussion expressed difficulty in visualizing the problem and integrating the linear mass density into their calculations. Helpful resources were shared to aid understanding, particularly in visualizing the magnetic forces at play. Ultimately, the feasibility of the magician's act hinges on accurately calculating the required current for suspension.
w3390
Your friend wants to be a magician and intends to use Earth's magnetic field to suspend a current-carrying wire above the stage. He asks you to estimate the minimum current needed to suspend the wore just above Earth's surface at the equator (where the Earth's magnetic field is horizontal). Assume the wire has a linear mass density of 10g/m. Would you advise him to proceed with his plans for this act?
dF=IdlxB, where dlxB is a cross product
I am having trouble understanding where to start. I am having trouble visualizing the problem and I don't know how to incorporate the linear mass density into anything. My book does not go over anything like this. Help on how to start would be much appreciated.
I do not understand how to get I from the equations in your second link. I understand what they mean and I have used them a lot, but I am not sure how the force is going to come into play.
Well it will take real magic then to suspend a wire.
If the qV got you then try
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/forwir.html#c1
Thank you so much. That last link does an amazing job at helping the visualization process. Once I could see what was happening, it made complete sense.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
