Solving for Parallel Tangent Lines: A Confusing Example
To find the point on the curve y = 1 + 2e^x - 3x where the tangent line is parallel to the line 3x - y = 5, the slope of the line is determined to be 3. The derivative of the curve is calculated as y' = 2e^x - 3. Setting this equal to the slope of the line gives the equation 2e^x - 3 = 3, leading to x = ln(3). The corresponding point on the curve is confirmed to be (ln(3), 7 - 3ln(3)). Graphical representation is suggested for better understanding.
zenity
I'm kinda stuck on this question... my text gives me a simple example, but it's far from enlightening. Just wondered if I could get some help!
"At what point on the curve y = 1 + 2e^x - 3x is the tangent line parallel to the line 3x -y =5?"
Would I just need to simply compare the slopes?
I found the derivative of the curve: y'= 2e^x - 3
So I suppose you just set 2e^x = 3... then you get x = ln(3)/2 ?
Thanks~
parallel means same slope, so u found \frac{dy}{dx} = 2e^x - 3
y=-5+3x, \frac{dy}{dx} = 3
3 = 2e^x - 3
3 = e^x
ln(3) = x
Oh, so I had to compute the derivatives for both slopes, then compare them? Interesting... thanks! I have to digest this info now.
-------> Should be -----> 2e^x - 3 = 3 -----------> x = ln(3)
Thanks~
zenity --
Your original approach was CORRECT. You just made the careless error shown above. Method is to determine slope of the line (compute dy/dx of the line OR determine by inspection (like you did) from the line's {y = mx + b} equation that the slope is "3") and then to equate this value to the curve's tangent slope (found by differentiating the curve's equation like you did).
so the point would be... ( ln(3), 7-3ln(3) ) ?
I'm just a bit confused graphically.
zenity said:
so the point would be... ( ln(3), 7-3ln(3) ) ? <----- CORRECT
Your answer is CORRECT. If helpful, sketch the graph to better understand the math. (Or use a graphing calculator.)
