Proof of Subgroup Property for Cyclic Group G: Homework Help
Mathematicsresear
Let G be a group. Assume a to be an element of the group. Then the set <a> = {ak I k∈ℤ} is a subgroup of G.
I am confused as to why the proof makes the assumption that <a> is a subset of the set G.
The proof I think is like the following:
As the identity element is in G it is true that it is also in <a>. Since for a general group G, the inverse is denoted as a0. Let b=ar and c=aj be elements in the group then araj is an element in the group due to the axiom of exponents... Now proving that there exists an inverse is done in an similar way but even though these three conditions are satisfied, shouldn't I prove that <a> is a subset of G?[/B]
What proof are you talking about? Is it a proof that you read?
Or are you asking whether a proof that you yourself write should prove <a> is a subset of G?
Yes you should.
If we split hairs, you should show that the phrase "the set ##<a> = \{ a^k | k \in \mathbb{Z}\}##" actually defines a set. After all, we can write down phrases that don't define specific sets - such as "##W = \{a+k | k \in \mathbb{Z}\}##".
You could use induction to show that ##a^k## has a defined result that is an element of ##G##.
Your approach beginning "Let ##b=a^r## and ##c=a^j## be elements in the group" only shows that if ##a^r## and ##b^j## are elements of ##G## then ##a^{r+j} ## is an element of ##G##. You hypothesize that ##a^r## is an element of ##G## instead of proving it and you didn't mention that ##a^{r+j}## is an element of ##<a>##.
Notice that a group operation is a function ##\circ: G \times G \to G##. That is, the product of 2 groups element is again in the group. Can you see how to apply that to find that ##a^k \in G## for ##a \in G, k \in \mathbb{Z}##?
Likes Delta2
Formally, yes. But as its proof is more or less straight forward, some authors might not feel the need to actually do it.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
