D.C motor speed controlImportant
  • Thread starter Thread starter KAS90
    Motor Speed
D.C. motor speed control can be effectively achieved using Pulse Width Modulation (PWM), which adjusts the average voltage supplied to the motor for precise speed regulation. The "novice method" likely refers to simply reducing the drive voltage, a less effective approach that may not provide the desired control. For basic speed adjustments, a variable series resistance can also be used, although it lacks the efficiency of PWM. It's important to note that higher PWM frequencies can lead to increased heat in the motor due to eddy currents, so selecting an appropriate frequency is crucial. Ultimately, PWM is recommended for more accurate and efficient speed control in D.C. motors.
KAS90
Hello everyone
I have a small question concerning D.C motors speed control. I would like to ask about the "novice method"? I can't seem to find enough information about it, so can anyone just give me a brief explanantion of it? and what is the circuit used for it? otherwise can you give me any other explanation and circuit of any other D.C motor speed control?
Thanks a lot.
I really appreciate it.
KAS90 said:
Hello everyone
Thanks a lot.
I believe you would usually use PWM of the DC input voltage to control the speed. Maybe the "novice method" is just reducing the drive voltage? That doesn't work very well, so maybe that's why they call it that?
By novice I think he just meant the easy way, in which case just decrease the voltage. If you need accuracy though use PWM.
I have never heard of the 'novice method' though like the other posts I feel that it indicates a simplified method of control. With a static input DC voltage, this can be done with a variable series resistance. I have included a PDF document attachment, which explains PWM and H-bridge control of DC motors, though the H-bridge is not the most simple of SCR DC motor control it is the most versatile. Its not great but I hope it is of some use.
One other point. The higher the frequency of the PWM signal, the more eddy currents will be produced and the hotter the motor will become. In other words, don't use a 40 kHz PWM signal if a 60 Hz PWM signal will suffice.
Thanks a lot everyone, I really appreciate it, the information was very helpful..
I think then I will end up using PWM method for my project..
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
