Can Data be Recovered from RAM?
In summary, the conversation discusses the possibility of recovering data from RAM and the challenges associated with it, such as the data being erased or overwritten when the computer is booted. The conversation also touches on the legality of accessing data through RAM and the difficulties of recovering data on modern computers. It is concluded that it is difficult and not worth the effort to try to recover lost data from RAM.
karthik3k
149
Data Recover from RAM ??
Is it possible to recover typed data from RAM ??
If so, how?
N if possible ... won't the data be erased/overwritten when i boot my computer ?
Plz reply.
Very urgent!
thanx in advance!
Computer science news on Phys.org
what do you mean?
hi,
I want to read data stored or access through RAM!
most programs do this... are you trying to do something illegal?
no. not illegal. its my Computer
I typed sth and lost it w/o saving the file...
i just hope that it might hav been saved in the RAM ...
BTW, how do they use it illegally ??
buffer overflows, u can read data you shouldn't be reading...
I don't think you are going to get the data back
On modern computers it's difficult. The modern memory technology which makes for cheap and fast memory also readily looses data when power is lost. Some other memory technologies are much more recoverable.
If you're really working at it, there may be possibilities, but it's almost certainly not worth the effort in your case.
The software that helps perform such tasks also costs money.
1. How does data recovery from RAM work?
Data recovery from RAM involves retrieving data that has been stored in the computer's memory (RAM) before it is cleared or overwritten. This is usually done by using specialized software that can scan and extract the data from the RAM, even if it has been deleted or lost due to a system crash or power outage.
2. Can all types of data be recovered from RAM?
It is possible to recover a wide range of data from RAM, including files, documents, images, videos, and even web pages. However, the success of data recovery depends on various factors such as the type of data, the length of time since it was lost, and the amount of available free space in the RAM.
3. How long does it take to recover data from RAM?
The time it takes to recover data from RAM varies depending on the amount of data and the complexity of the recovery process. In some cases, it can take only a few minutes, while in others it may take several hours. It also depends on the speed and efficiency of the data recovery software being used.
4. Is data recovery from RAM a safe process?
Yes, data recovery from RAM is generally considered a safe process. The software used for data recovery does not write or make any changes to the RAM, so there is no risk of further data loss. However, it is always recommended to back up important data regularly to avoid the need for data recovery.
5. Can data be recovered from damaged RAM?
In most cases, data can be recovered from damaged RAM. However, this depends on the extent of the damage and the type of data that has been stored in the damaged RAM. In some cases, physical damage to the RAM may make data recovery impossible, but software-based recovery methods may still be able to retrieve some of the data.
  • Electrical Engineering
  • Computing and Technology
