Impact of Adding Resistor on DC Circuit Current
  • Thread starter Thread starter maiad
    Circuits Dc
Adding a third resistor in parallel to two existing resistors in a DC circuit will decrease the total resistance, leading to an increase in the total current supplied by the battery. The potential difference remains constant across all resistors, but the current is distributed among them according to their individual resistances. Kirchhoff's Current Law indicates that the total current entering a node equals the total current leaving, which means the battery's current will adjust based on the combined resistance of the parallel configuration. The discussion emphasizes understanding how current distribution and potential difference interact in parallel circuits. Overall, adding a resistor in parallel affects the current flow and distribution in the circuit.
maiad
Let's say i have a circuit with two resistors connected in parallel with some source. Then another resistor is added in parallel with the first two so what happen to the current in the battery?
Should the current in the battery decrease since the potential is split across the three resistors?
The third resistor is parallel to the other two parallel ones. The common points are connected to the terminals of the battery. So what about the potential difference across all resistors?
Did not you mean that the third resistor is connected in series with the other two parallel ones? ehild
No it's is what it is, first there where two in parallel then there was three. The potential difference should the same across all the resistors but current would be distributed, but I'm not sure how this would affect the current going through the battery since the current would meet back up and go through the battery anyways
What is the current through a resistor R when the potential difference is V across it?
What does Kirchhoff's Current Law state about the currents at a node? ehild
