How Do Inductors and Back EMF Influence DC Motor Behavior?
Inductors and back EMF are crucial in modeling DC motors as they influence current flow and torque. The inductor helps manage changes in current, while back EMF opposes input voltage, adjusting current based on motor speed. When a load changes, the motor must accelerate or decelerate to reach a new steady speed, demonstrating the conservation of energy. The back EMF varies with speed, providing intrinsic feedback that regulates current and torque, ultimately controlling acceleration. This dynamic interplay ensures efficient motor operation under varying loads.
perplexabot
Hello. Just started learning about how to model a DC motor. A simple model consists of the input Voltage in series with an inductor, a resistor and a back emf. I have two questions.
Why have both the inductor and the back emf (voltage source)?
If you know that at a voltage V and a load L1, the motor will have a steady speed of w1.
Now say we remove the initial load and attach another load L2 keeping the input voltage at V.
Will the motor still be able to reach a steady speed (i know it will not be w1)? In other words will it accelerate/decelerate or have a constant velocity?
EDIT:
So now I just realized it has to accelerate/decelerate in order to reach a steady state, I also figured out that it cannot keep accelerating (that would defy the law of conservation of energy). So now I have another question, does the back emf change accordingly to adjust the current which in turn adjusts the torque (is this the "intrinsic feedback of the motor")? Is it this process that controls the acceleration?
The back emf adjusts with speed thereby controlling the current through the resistor. The torque is proportional to the current through the resistor. The power is the angular velocity times the torque and is also the current times the back emf. The inductance is there because it affects the overall ideal transfer function.
The following is a nice explanation:
http://ctms.engin.umich.edu/CTMS/index.php?example=MotorSpeed&section=SystemModeling
Likes 1 person
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
