DE book does not justify this claim
  • Thread starter Thread starter 1MileCrash
    Book
1MileCrash
My DE book claims that
\frac{d\mu(t)/dt}{\mu(t)}
is equivalent to
\frac{d}{dt}ln|\mu(t)|
But says nothing to justify this claim.
Can you?
Why would it? Most Authors would assume that if a student is studying differential equations, they have already mastered the basics of single variable calculus, such as computing derivatives and anti-derivatives.
This is just an application of the chain rule, combined with the fact that \frac{d}{dx} \ln|x| = \frac{1}{x}.
I see how from the bottom, the top follows by direct application of the chain rule.
But given the top, I don't know how to come to the bottom expression.
But that seems just like the chain rule , (though I don't know why they dropped the
absolute value): d/dt f(g(t))= f'(g(t))g'(t) , where f(t)=ln|t| g(t)=u(t). Or
maybe you can do a triple chain rule f(g(h)) , with g(t)=|t|, h(t)=u(t), and
f(t)=ln(t).
Just compute the anti-derivative:
\int \frac{ \frac{d\mu}{dt} }{ \mu(t) }dt = \int \frac{d\mu}{\mu} = \ln|\mu| + C
More importantly though, given how common a function the natural logarithm is, you need to be able to recognize its derivative when you see it. A big part of problem solving with differential equations requires you to have experience with calculating common derivatives (which is why most calculus textbooks have all those practice problems in them :wink:) and applying that experience, by recognizing derivatives of common functions when you see them.
Remember that:
\large \frac{δ}{δt}ln|x|=\frac{1}{x}
but since you have a another function inside the log, you need to apply the chain rule, so:
\large \frac{δ}{δt}ln|\mu(t)|=\frac{1}{\mu(t)}\cdot\frac{δ\mu(t)}{δt}
That's not really my issue. I just like to see it written out even if it is recognizable - I can integrate and differentiate until the cows come home.
Nonetheless:
\frac{d\mu(t)/dt}{\mu(t)} = q
Integrating both sides
ln|\mu(t)| = qt
Then taking the derivative of both sides
\frac{dln|\mu(t)|}{dt} = q
Therefore:
\frac{d\mu(t)/dt}{\mu(t)} = \frac{dln|\mu(t)|}{dt} = q
Is satisfactory.
Nonetheless:
ln|\mu(t)| = qt
This all seems kind of pointless. Integrating ##\frac{d\mu(t)/dt}{\mu(t)}## to get ##\ln|\mu(t)|##, you've used the fact you're trying to show, so why bother? Also, the righthand side is only equal to qt if q is a constant, which it most likely isn't.
q is constant, I just put it there so I could visualize it thoroughly.
But you defined q as being equal to \frac{ \frac{d\mu(t)}{dt} }{\mu(t)}, so it is only constant if \frac{ \frac{d\mu(t)}{dt} }{\mu(t)} is constant, which it isn't, in general.
It is constant, here.
If it weren't, instead of qt it would be an arbitrary integral notation of q. It doesn't matter.
Bacle2 said:
though I don't know why they dropped the absolute value
Try computing \frac{d}{dx}\ln(x) when x<0. There's a reason that calculus books give the antiderivative of \frac{1}{x} as \ln|x|+C instead of \ln(x)+C.
