Decompose the E field into conservative and non-conservative parts
  • Context: High School
  • Thread starter Thread starter alan123hk
    Field parts
The discussion revolves around the decomposition of electric fields into conservative and non-conservative parts, particularly in the context of circuit analysis and electromagnetic theory. Participants explore the implications of this decomposition for practical calculations and theoretical understanding, referencing specific examples and models.
  • Some participants suggest that splitting electric fields is a useful calculation method, particularly in circuit analysis, while others argue it is unnecessary if the lumped element model is valid.
  • One participant provides an example involving a transformer and voltage loop equations, claiming that splitting the electric field simplifies calculations.
  • Another participant emphasizes that if the magnetic field is zero, all EMFs are produced by potential electric fields, allowing for the use of potential functions without the need for splitting.
  • Concerns are raised about the validity of the EMF source in the provided diagrams, questioning whether the lumped element model applies.
  • Some participants discuss the Lewin circuit paradox, with differing views on whether it represents a genuine paradox or a misunderstanding of the lumped model.
  • A later reply introduces a more theoretical perspective, discussing the mathematical properties of electromagnetic fields and the implications of gauge transformations on electric and magnetic potentials.
Participants express differing views on the necessity and validity of splitting electric fields in circuit analysis. While some find it a helpful method, others argue against its necessity, leading to an unresolved discussion with multiple competing perspectives.
Participants reference specific conditions under which their arguments hold, such as the assumption of no time-varying magnetic fields and the applicability of the lumped element model. The discussion also touches on the limitations of the provided diagrams and the clarity of the proposed calculation methods.
  • #31
I suggest you take a look at this video. This may make you more familiar with this interesting story that started many years ago. :smile:
  • #32
alan123hk said:
EMF per quarter of the arc length
On your diagram, I'd call this into question:
The EMF is proportional to the angle (this is to be proven separately). As shown on the picture above, angle ##\varphi## is less than ##\pi/2##, so ##\epsilon<0.25V##.
This is what I was talking about: The solution does depend on geometry, lumped elements' dimensions now matter. You have provided numerical results without giving exact problem conditions. And I asked you to argue them.
  • #33
Since I marked both top and bottom as 0.25V, this already shows that the length of the resistor is assumed to be infinitely small, and the electric field inside the resistor becomes infinite, but the voltage of the resistor is still a fixed value. If I draw that resistor too small, it will be hard for people to see it.
In the example below, we can write the instant result 0.2V without solving complex voltage loop equations.
Is there any other way to find the answer so quickly without using the SPLIT FIELDS method?
  • #34
I don't know, how you come to take two points and put some voltage on in it in a situation, where you have an EMF due to to a time-varying magnetic field. Due to Faraday's Law,
$$\vec{\nabla} \times \vec{E}=-\partial_t \vec{B}$$
there's no scalar potential for ##\vec{E}##, and the EMF between two points depends on how you measure it. That's well demonstrated in this (in)famous lecture by Lewin quoted somewhere above, if I remember right. All you can say is that
$$\int_C \mathrm{d} \vec{r} \cdot \vec{E}=-\dot{\Phi}=1 \text{V},$$
where ##\Phi## is the magnetic flux through an arbitrary surface with boundary ##C##. Choosing ##C## to run "along the circuit" the conclusion is that there is a current ##i## and Faraday's Law then tells you that ##I=1 \text{V}/[(0.1+0.9) \Omega]=1 \text{A}##. Which voltages you measure between any two points "on the circuit" depends on the wiring of the voltmeter you attach to the two points!
  • #35
This is what I've been trying to express all the thread long.
As far as I understand the idea, he tries to decompose the resulting E-field into the solenoidal one having a constant value along a circle arond the flux (due to symmetry) and the conservative one, produced by induced charges, to finally satisfy Ohm's law along resistors and perfectly conducting wires.
It's possible to do that, but I can't still catch why. Your solution above for the loop current (and hence the EMFs along the two resistots) is straightforward.
  • #36
If all you have in your toolbox is a hammer, everything begins to look like a nail.
One can likely contrive situations where this approach has hueristic appeal. In general, for reasons well stated, it is a "solution" in search of a problem. For your symmetry argument to hold, the entire magnetic universe would need to be cylindrically symmetric. Might be tough.
Stokes theorem deals with closed curves for a reason
  • Haha
  • #37
@vanhees71
I'm not trying to describe the non-existent potential created by the induced electric field, but the scalar field created by the accumulated charge on this circuit.
As is the case in this paper http://kirkmcd.princeton.edu/examples/lewin.pdf , the same circuits are also described with potentials. Quoted below.
  • #38
The following example explicitly shows the presence of a scalar field generated in the circuit.
Note that the direction of the circular induced electric field is at right angles to the direction of the wires connected to the voltmeter, so the induced electric field does not generate any emf on the wires. Now look at a plane at right angles to the ring circuit. If the voltmeter and its connecting wires are moved to any position on the plane, the displayed reading will not change, because the direction of the two wires is always at right angles to the induced electric field, so it must be measuring the potential difference generated by the accumulated charge in the circuit.
Some people may say why to complicate things, it seems that it has no practical value. But I disagree, like the above example, at least we understand what is measured and why the voltage change is measured when the wire connected to the voltmeter deviates from this plane, maybe it can be used to detect whether the plane in the mechanical structure deviates from the original position. :smile:
  • #39
The last equation ##V=\epsilon \frac \phi {2 \pi}+const## is obviously false, because here V for angle zero is either undefined or experiances a leap. But any scalar potential function has to be continuous.
  • #40
alan123hk said:
Some people may say why to complicate things, it seems that it has no practical value. But I disagree, like the above example, at least we understand why the voltage change is measured when the wire connected to the voltmeter deviates from this plane, maybe it can be used to detect whether the plane in the mechanical structure deviates from the original position. :smile:
Two practical points:
The indiced emf is proportional to the time derivative of the flux and therefore seldom constant and happy
A standard form of magnetic field sensor (prior to hall effect sensors and FETs) was the flip coil.
Generally the fact that one can perform a Helmholtz decomposition of any well behaved vector field is not news and, while occasionally useful, it should not be extorted with the hammer.
  • #41
SDL said:
The last equation V=ϵϕ2π+const is obviously false, because here V for angle zero is either undefined or experiances a leap. But any scalar potential function has to be continuous.
Sorry, I really don't understand why this is going wrong. This constant means that when the angle is 0, V can be any value. This is a boundary condition and the user may decide to substitute any value.
  • #42
This is a physical phenomenon. Whether it is useful or has practical use depends on each individual's opinion and situation. I respect your opinion even if you say it's completely useless, but I don't understand what you mean by extortion.
  • #43
This is true, but the problem isn't here. Assume the constant equals to zero. Angles 0 and ##2 \pi## are actually the same. At angle 0 V is 0 and at ##2 \pi## it equals to ##\epsilon##. Thus the potential is not defined. If we force V to be 0 at angle 0 anyway, then there would be a leap of this function and this is not allowed.
  • #44
SDL said:
This is true, but the problem isn't here. Assume the constant equals to zero. Angles 0 and 2π are actually the same. At angle 0 V is 0 and at 2π it equals to ϵ. Thus the potential is not defined. If we force V to be 0 at angle 0 anyway, then there would be a leap of this function and this is not allowed.
You are right, now I also think there is something wrong with this equation, I don’t understand either
  • #45
Think, it was a challenge :wink:
  • #46
I didn't study this article carefully before, but now I understand that one of the key points is as follows.
Equation 22 describes the induced electric field strength, which is constant at every point throughout the ring, and Equation 23 describes the electric potential, whose value increases with angle. Then why it can draw the conclusion of equation 23 from equation 22. Since the electric field inside the perfectly conducting wire is zero, it must be because the electric field generated by the charges accumulated on the surface of the wire cancels the induced electric field inside the wire. Then the potential generated by the accumulated charge on the surface of the wire should also increase proportionally with the increase of the angle. This is consistent with what I've been saying. I believe it is difficult for each side to understand what the other is thinking without separately considering the electric field created by the accumulated charge on the surface of the wire.
  • #47
There is no decomposition of the E-field involved. All you need is Faraday's Law as shown in #34.
  • #48
alan123hk said:
@vanhees71
It's described by a scalar AND a vector potential, and that must be so, because the electric field is not a conservative field in this case, due to Faraday's Law!
  • #49
Some references for the surface charge of current-carrying conductors.
Includes a demonstration of an electric field that actually exists in the surrounding space outside a current-carrying conductor.
https://physicsteacher.blog/tag/surface-charges-on-current-carrying-conductor/
https://zjui.intl.zju.edu.cn/course/ece329/Secure/LectureNotesforCalendar/optional/Jefimenko62.pdf
http://matterandinteractions.org/wp-content/uploads/2016/07/circuit.pdf
Can't we then try to describe and calculate the real electric field produced by a current-carrying conductor?
  • #50
Are these published in peer-reviewed format anywhere?
  • #51
It's in any textbook on electromagnetism, and you don't need to rely on peer-review, if you calculate it yourself.
The most simple case is a very long coaxial cable. with a battery on one end and a resistor (or a short circuit) on the other. Then (in non-relativistic approximation) you can make the ansatz that ##\vec{j}=j \vec{e}_3## (where the cable is along ##\vec{e}_3##) with ##j=\text{const}## along the wires and ##0## outside.
Then you can solve the static Maxwell equations together with the appropriate boundary conditions and get the surface charges along the surfaces as well as the electric and magnetic fields everywhere.
  • #52
simple question. In the following system, due to the induced electric field generated by the inductance, there must be only one electric field, which is a non-conservative field.
But how could there possibly be a faster and easier way to find an approximation of this non-conservative field without separately considering the electric field generated by the charges on the two plates of the capacitor?
  • #53
You just use the usual quasistationary approximations of circuit theory and Faraday's Law then leads to
$$L \dot{i}=-CQ.$$
Using ##\dot{Q}=i##, you get
$$L \ddot{Q}=-C Q \; \Rightarrow \; \ddot{Q}=-\omega^2 Q, \quad \omega=1/\sqrt{LC}$$
The solution is
$$Q(t)=c_1 \cos(\omega t) + c_2 \sin(\omega t),$$
with the integration constants ##c_1## and ##c_2## given by the initial condition, i.e., ##Q(0)=Q_0## and ##i(0)=\dot{Q}(0)=i_0##.
  • #54
This is just to find out the current, voltage and the amount of charge on the capacitor . I mean find out the electric field in all the surrounding space. The electric field in the entire space includes the induced electric field generated by the inductor and the electric field generated by the capacitor. They are stacked together.
I admit that there is only one non-conservative field, but on the other hand, how can there be a faster way to find this non-conservative field (even an approximation) directly without considering the electric fields generated by the inductor and capacitor separately?
  • #55
In order to find a useful approximate solution, one must rigorously define the purpose and range of the approximation, and never lose sight of the validity thereof. Much good physics has been done by making assumptions and rigorously deriving the results thereof.
Hans Bethe, for instance, was famous for making the correct ansatz in an otherwise intractible situation. But he never lost sight of the limitations and sometimes figuring out why such an ansatz works better than expected reveals hidden details.
  • #56
Maybe this reference would help:
https://web.mit.edu/6.013_book/www/chapter10/10.1.html
See "Example 10.1.2. Electric Field of a One-Turn Solenoid".
The reference above is a chapter from this book: Herman A. Haus, James R. Melcher. Electromagnetic Fields and Energy.
https://www.amazon.com/dp/013249020X/?tag=pfamazon01-20
  • #57
Thank you for your replies, I think I need some time now to sort out and think about related issues.
  • #58
  • #59
https://web.mit.edu/6.013_book/www/chapter10/10.1.html See "Example 10.1.2. Electric Field of a One-Turn Solenoid".
Thanks for the link, Example 10.12 demonstrates how to use good mathematical techniques to derive analytical solutions to physics problems.
Below I try to find potential and potential difference using the simple concept I've been talking about. It is to regard the entire cylindrical structure as a circuit to calculate. Of course, this does not have the ability to find the electric field distribution in the entire space, since Laplace's equation and other more advanced mathematics have to be used.
  • #60
Which is unique. QED.
10K
  • · Replies 36 ·
