Evaluate Definite Integral using Right Hand Rule
  • Thread starter Thread starter DemiMike
DemiMike
Use the definiton of the definite inegral (with right hand rule) to evaluate the following integral. Show work please
Can NOT use shortcut method.. but be the long process
S (3x^2 - 5x - 6) dx
-4
\int_{-4}^{1}(3x^2-5x-6)dx=\int_{-4}^{1}3x^2dx-\int_{-4}^{1}5x-\int_{-4}^{1}6dx=3\frac{x^3}{3}-5\frac{x^2}{2}-6x]_{-4}^{1}
=\frac{145}{2}
But i don't understand "with right hand rule".What do you mean?
I suspect DemiMike means using the Riemann sum definition, using the right end point of each subinterval as the height of the rectangle.
And, of course, requiring that it be done in a particular way makes it sound an awful lot like homework, so I am moving it. DemiMike, please post school work in the appropriate place.
Also, whether homework or not, you must show some effort to do the problem yourself. This particular problem is a bit tedious but a straightforward calculation.
this is what i got ./.i want to see what other people get first
∫[-4,1] (3x^2 - 5x - 6) dx =
lim[n-->∞] 5/n ∑[i=1 to n] {3(-4 + 5/n)² - 5(-4 + 5/n) - 6} =
lim[n-->∞] 5*∑[i=1 to n] (48/n - 120i/n² + 75i²/n³ + 20/n -25i/n² - 6/n) =
lim[n-->∞] 5*∑[i=1 to n] (62/n - 145i/n² + 75i²/n³) =
lim[n-->∞] 5[62n/n - 145n(n+1)/(2n²) + 75n(n+1)(2n+1)/(6n³)] =
5(62 - 145/2 + 25) = 72.5
∑[i=1 to n] 1 = n
∑[i=1 to n] i = n(n+1)/2
∑[i=1 to n] i² = n(n+1)(2n+1)/6
so any 1 ?
Looks good :smile:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
