Determining the Definite Integral for Positive Integers: An Exploration
You guys are the best!In summary, by appealing to geometric evidence, it is shown that \int_0^8x^n\,dx + \int_0^1 x^{1/n}\,dx = 1 for n a positive integer. This is due to the fact that the curves x^n and x^1/n are mirror images of each other, reflected about the line y=x. Therefore, the area between the x^1/n, the y-axis, and the line y=1 must equal the area between x^n, the x-axis, and x=1. Furthermore, the area above x^1/n must equal the area below x^n, resulting in a total area of 1. This also
Dorothy Weglend
247
By appealing to geometric evidence show that
[tex]\int_0^8x^n\,dx + \int_0^1 x^{1/n}\,dx = 1[/tex]
Fundamental theorem of calculus, power rule for integration.
I integrated. For the first integral, I get:
[tex] \frac{8^{n+1}}{n+1}[/tex]
and for the second:
[tex] \frac{n}{n+1} [/tex]
As an experiment, I tried this for a few values of n, for example, n=1 gives [itex] 8^2/2 + 1/2 = 32.5 [/tex], which is certainly not 1.
So obviously something is awry here. I think I integrated properly, but perhaps not.
Can someone shed some light on this for me?
Thank you,
Dorothy
The "8" should be a "1". :smile:
Arildno's point is that
[tex]\int_0^1x^n\,dx + \int_0^1 x^{1/n}\,dx = \frac{1}{n+1}+ \frac{n}{n+1}= 1[/tex]
But what you give is NOT always equal to 1.
Since the problem says "by appealing to geometric evidence", those integrals are the areas of what regions?
Thank you both, so much! It must be a mistake in the text. Now the problem seems solvable.
To answer your question, it seems to me that the geometric argument would go something like this: the curve x^n and x^1/n are mirror images of each other, reflected about the line y=x (as they are inverse functions). Therefore the area between the x^1/n, the y-axis and the line y=1 must equal the area between x^n, the x-axis and x=1. So this area, plus the area below x^1/n must equal 1.
Well, that's how it looks to me, anyway. Hope this is correct.
Thank you!
Dorothy
The two part areas do NOT equal each other, but their sum is, indeed 1.
But how is that possible, if they are mirror images, the area above x^1/n must equal the area below x^n. Otherwise I don't see how they can sum to 1. What am I missing?
Draw the unit square, and the curve y=x^n through it.
This partitions the unit square in two areas whose sum are one.
The area bounded by the x-axis, y=x^n and x=1 equals 1/(n+1)
The area bounded by the y-axis, the curve x=y^(1/n) and y=1 is n/(n+1)
Note that x=y^(1/n) denotes exactly the same curve as y=x^n.
The reflection about the line y=x occurs when you go from describing the SAME curve equivalently as [itex]y=f(x)[/itex] or [itex]x=f^{-1}(y)[/itex] to describing the different curve [itex]y=f^{-1}(x)[/itex] (equivalently described by x=f(y))
I'm not sure why you changed the variables here. It still seems to me the areas must be equal. The original equations, y=x^n and y=x^1/n. the second one is equivalent to y^2 = x.
Therefore the distance from the x-axis to the curve y=x^2 must be the same as the distance from the y-axis to the curve y^2 = x:
y=(0.5^2) = 0.25, distance from x-axis to curve is 0.25
x = (0.5^2) = 0.25, distance from y-axis to curve is 0.25
Therefore the areas must be equal (That is, the area above x=y^2 must equal the area below y=x^2).
Or another way to view it: The area beneath the curve x^1/n is n/(n+1). The area above it is 1 - n/(n+1) = 1/(n+1), which is the same as the area below the curve x^n.
This also implies that the curves of x^n and x^(1/n) are reflected about y=x.
In fact, I think we are both saying the same thing.
Dorothy
Dorothy Weglend said:
(1) There fore the area between the x^1/n, the y-axis and the line y=1 must equal the area between x^n, the x-axis and x=1. (2) Together, they form a square of area 1.
Okay, I misread a bit what you said.
The above statement (1) is correct, statement (2) is incorrect.
In addition to those two areas, you have the area of the region symmetrical about y=x, bounded by the curves y=x^n and y=x^1/n
Ah, thanks arildno. And I also mistyped in my first post, I will correct that now.
Thanks again for all your help.
1. What is a definite integral?
A definite integral is a mathematical concept that represents the area under a curve on a graph. It is used to find the exact value of an area between two points on the curve.
2. How is a definite integral different from an indefinite integral?
A definite integral has specific limits of integration, while an indefinite integral does not. This means that a definite integral will give a numerical value, while an indefinite integral will give a general function with a constant of integration.
3. What is the process for solving a definite integral problem?
To solve a definite integral problem, you first need to find the antiderivative of the function. Then, plug in the upper and lower limits of integration and subtract the upper bound from the lower bound to find the area under the curve.
4. What are some real-world applications of definite integrals?
Definite integrals have many real-world applications, such as calculating volume, acceleration, and work. They are also used in economics, physics, and engineering to model and analyze continuous processes.
5. Are there any techniques for solving difficult definite integral problems?
Yes, there are several techniques for solving difficult definite integral problems, such as substitution, integration by parts, and trigonometric identities. It is also helpful to have a good understanding of properties of integrals and practice solving various types of problems.
