How Do You Calculate Force on a Water Jet Deflected by a Plate?
michael7777
A jet of water going through a nozzle is deflected by a flat plate. Get Q, Velocity, Force
The volumetric flow rate of water through the nozzle is 10 Litres in 7 seconds
The water temperature is 20 degrees celcius.
We are using a flat plate so theta = 90 degrees
Velocity coefficient C = 1
Q (volume flow rate) = volume / time
Velocity = Q / area of nozzle
Force = density of water * Area of nozzle * velocity^2 * (1 - C*cos theta)
Density of water at 20 degrees = 998.2 kg/m^3
Q = 0.01 / 7
Q = 1.429 (10^3) m^3/s
I don't know how to get area of nozzle
Using C = 1, theta = 90:
F = 1000 * area of nozzle * V^2
Hi michael7777! :smile:
I agree with you … there isn't enough information. :confused:
(btw, another way of calculating it is force = rate of change of momentum = mass x velocity/time … but again, we don't know the velocity. :cry:)
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
